mbosnic
Transparent WiFi AP
Fri Sep 22, 2017 12:45 pm
Hello.
I am trying to configure Mikrotik Groove 52HPn as an access point for a UDP camera stream (3 cameras to be exact). Cameras are connected by ethernet cable to Cloud Router Switch CR112-8G-45-IN. Groove is also connected with ethernet cable to that switch. Switch is unconfigured and is working as needed. PC1 is receaving stream from cameras without any problem. Cameras are broadcasting UDP RTP stream.
Groove is configured as ap-bridge, with a bridge configured on both ethernet and wlan interfaces.
However, the streams are not showing on PC2. What am I doing wrong with this configuration?
pukkita
Trainer
Trainer
Re: Transparent WiFi AP
Fri Sep 22, 2017 3:06 pm
Try this:
- Go to Wireless, open wlan1-gateway, click on [Advanced Mode] button, and set Multicast Helper to full.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
scampbell
Trainer
Trainer
Mon Sep 25, 2017 1:44 am
You might also wish to set the Wireless Protocol to 802.11 instead of "any" :-)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: No registered users and 8 guests
