MUM Europe 2020
soleed
Link Test !!
Thu Dec 07, 2006 10:57 pm
please exuce me for this question but im still new in microtik ,
i just setup a link 20km direct visible bridge connection with wds
when i do ping i get a delay of 100ms and 200ms
how i can test my link spead an load
RaMi.
Equis
Forum Veteran
Forum Veteran
Thu Dec 07, 2006 11:42 pm
100 -200ms something is wrong, should be <5-10ms
You can use bandwidth test and server, have a look in tools menu (in winbox)
What is you signal level?
Can you change channel?
I have 40km link with crappy LOS and get <5ms & <20ms under load.
soleed
Sat Dec 09, 2006 11:44 pm
SIR,
signal level is -75 ~ -80
normis
Mon Dec 11, 2006 10:17 am
that's not a good signal, try adjusting your antennas or changing the frequency. good signal is -60
CREATIVELINK
Mon Dec 11, 2006 11:27 am
CREATIVELINK
Mon Dec 11, 2006 11:32 am
in this case can i change only the ap bridge signal ?? or i must change't in all the points , and if i change the apbridge signal thru network i will loose the connection ?
nickb
Tue Dec 12, 2006 8:42 pm
Uh, you realize you have to physically DO something (like move an antenna, or redo a cable) to change the signal, right? It's not exactly something you can change in the software, except by reducing tx-power - which you don't want to do!
At 20km with direct visible line of sight you should have, as the others said, 5-20ms pings under load and around -60 signal.
You probably need to check your pigtails, cabling, and antenna allignment.
Users browsing this forum: No registered users and 13 guests
