Hi Everyone,
I need some assistance please with a Capsman setup.
My setup
Mikrotik Router with Capsman
Ethernet #3 to Switch (Local Network)
Ethernet #5 to Fiber (Public)
I have 13 MAP's controlled by Capsman
Each has its own Bridge
Each has its own DHCP server i.e
Bridge 1 - 10.10.1.1-10.10.1.199 - DNS 8.8.8.8 - Gateway 10.10.1.254
Bridge 2 - 10.10.2.1-10.10.2.199 - DNS 8.8.8.8 - Gateway 10.10.2.254
and so on.
With this I was able to set up mangle rules to mark each bridge and a Queue tree to enable QOS via PCQ on each bridge.
This works perfectly and exactly as I intended.
The DHCP is set up on the capsman and hands out addresses to each device connecting to a MAP through the wireless Interface
The problem that I have is with the MAP
1. If multiple devices are connected to the same MAP they cannot see each other or ping each other, would enabling Client to Client Forwarding solve this? And if so would that only allow the devices connected to that MAP (i.e Bridge) to see each other, in other words Bridge 1 and bridge 2 would still not be able to communicate?
2. I would like the DHCP to extend to the second Ethernet interface on the MAP, i.e if I connect a Desktop or soothing the Ethernet #2 that it is also allocated an address via the Capsman DHCP and works as if it was connected wireless.
Any Advice.
Regards
