breadgreen
Mikrotik CAPSMAN + SONOFF(ITEAD) devices
Tue Dec 26, 2017 7:29 am
I have an issue to connect my sonoff devices to my capsman wifi network. The problem is, that these devices just can't to connect. BUT, the big BUT. I used to have simple wifi, not CAPSMAN and all works good. I can't understand what's the difference? The range is same, frequency is same, wifi type is same! Maybe something wrong with routes, but it's just a suggestion. And by the way, when i make hotspot on my cellphone using mobile data connection, all works good!
Please anybody give me a piece of advice, in which way i need to dig in to find a solution?
haik01
Re: Mikrotik CAPSMAN + SONOFF(ITEAD) devices
Sat Dec 30, 2017 2:53 pm
And if you connect your mobile phone to the Capsman network, (or your laptop), do these devices work?
breadgreen
Tue Jan 02, 2018 8:39 pm
did you mean internet and other network? yes sure it works normal.
AlfaGulf
Sat Mar 02, 2019 10:48 am
Have you solved your problem? if so how?
Please share for the benefit of the community.
Malco
Thu Mar 28, 2019 3:29 pm
Same problem here, any suggestion?
ivanfm
Fri Mar 29, 2019 8:30 pm
My home network is capsman based. I got 10 sonoff basic installed in the network without much problems.
I have used the "Compatible Pairing Mode (AP)" from the ewelink app on Android.
The "Quick Pairing mode (Touch)" which is the default mode does not worked.
raceboy
Fri Mar 29, 2019 8:41 pm
flash your sonoff with esp easy (letscontrolit.com). i have all sonoffs works
Sent from my Moto G (5) Plus using Tapatalk
gutekpl
Fri Mar 29, 2019 10:25 pm
I have capsman based on 2 devices - hap ac2 + cap ac and few sonoffs (basic, dual, pow), each one of them works fine, without any issues while pairing. I used standard quick pairing in ewelink app. You can paste You capsman config screenshots, so I can compare them with mine settings if You like.
Users browsing this forum: No registered users and 15 guests
