Lotli
Dual sim wifi router for buses
Thu Jan 25, 2018 6:43 pm
I was wandering if someone have any routerboard with dual sim slots and wifi 2.4 (prefer dual band 2.4/5ghz, but can be whithout). I need it for wifi hotspot project for tourist busses. I found the RBM33G, but it has no wifi cards.
Aufan388
Re: Dual sim wifi router for buses
Fri Jan 26, 2018 11:35 am
The only option I can see IF you want to use Mikrotik for this is RB953GS-5HnT-RP with an additional 2.4GHz AP connected to an ethernet port to get 2 SIMs and Dual Band WiFi coverage. A bit expensive but should meet all your requirements...just a bit overkill on the 5GHz side, though :P
https://mikrotik.com/product/RB953GS-5HnT-RP
LTE you can try recommended 3rd parties or buy direct from Mikrotik:
https://wiki.mikrotik.com/wiki/Supported_Hardware
Lotli
Fri Jan 26, 2018 12:11 pm
Thanks. quite risky for mobile bus solution. is there dual sim board with 2.4ghz?
BTW
The LTE link is empty
Aufan388
Fri Jan 26, 2018 4:42 pm
Unfortunately, I can only see either 2 SIM or 1x SIM w/ 1x WiFi options...besides the 5GHz option I already wrote about.
The LTE link isn't empty, just scroll down further ;) I thought the same at first :-P
antonsb
Fri Jan 26, 2018 6:27 pm
You can use M33G with 1 x mPCIe modem and 1x USB modem + Wireless card.
haik01
Fri Jan 26, 2018 7:00 pm
Is there a reason for dual SIM?
Lotli
Sat Jan 27, 2018 7:33 pm
The main reason for dual sim is 4g/3g is failover in case of coverage issues of mobile providers. BUT bandwidth muxing can be as well a benefit incase of overload users.
jspool
Sat Jan 27, 2018 11:47 pm
Pepwave Max BR1 already does all of this. While you may be able to cobble Mikrotik stuff together to make something work I think you would find the Max BR1 pretty awesome and rugged for that use case. The Sierra Wireless ES450 is also a great unit for single SIM use.
Lotli
Mon Jan 29, 2018 12:17 am
Thanks for all your replies.
I herd about the Pepwave Max BR1 but i dont have experience with them, and as far as i see they are quite pricey.
juliokato
Mon Jan 29, 2018 12:52 pm
Look this: (go to page 31)
https://mum.mikrotik.com/presentations/ ... 613097.pdf
But do not expect this product to be available later this year.
I'm still waiting for the WAP LTE KIT, the distributor does not have availability yet and it was announced in 2017.
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
Lotli
Tue Jan 30, 2018 6:25 pm
Wow the LtAP looks like the right solution.
Users browsing this forum: No registered users and 23 guests
