vaah
How to diagnose sxt sa5ac wireless problem?
Wed Jan 31, 2018 6:29 pm
I have 2 SXT5AC i set up as ptp bridge between house A and B with distance of about 200-300 meters . This afternoon suddenly the one at my house B acting as station bridge disconnected. It wouldn't reconnect to the AP. I reboot the device and it still wont connect.
I begin to suspect there might be something wrong with the wireless module itsellf. I tried using scan and snoop tools, no ssid entries came up when scanning... while the other device display some ssid cluttering my neighbourhood.
How can i confirm if there is something wrong with the wireless module itself? How to diagnose? Thanks in advance.
Sent from my SM-T705 using Tapatalk
vaah
Re: How to diagnose sxt sa5ac wireless problem?
Fri Feb 02, 2018 10:18 am
BUMP..
anyone got ideas?
vaah
Fri Feb 02, 2018 10:34 am
I added screenshot to explain better what i meant.
This is the SXT at my site, I ran scan and freq. usage tools.
And this the SXT AP, when I ran scan and freq. tools. You will see this one can see other SSIDs around the premise.
What do you think? any suggestion at all? These device haven't been running more than 5 months and has already giving me trouble..
allstarcomps
Fri Feb 02, 2018 7:04 pm
Have you done a reset configuration on the SXT, then a wireless scan? If it produces the same results then I would do a net install of a bug fix only release and try it from there. If nothing changes I would suggest doing an RMA on the device.
vaah
Sat Feb 03, 2018 6:15 pm
Yes, i did reset config on it, by pressing the black button near the ethernet port. Still nothing came up on wireless scan tool result. I haven't done netinstall however. I'll try it and report back. but i'm a bit skeptical.
vaah
Tue Feb 06, 2018 7:41 am
Okay, I did netinstall and the symptom is still the same, wireless scan doesn't show anything. Is my SXT consider a goner now?
Anyone else have any suggestion?
vaah
Tue Feb 06, 2018 7:47 am
On another note, I'm planning to get SXTsq Lite5 for the time being, is it gonna work with my sxt sa5ac? I notice my current wireless is ac and the SXTsq Lite5 will be using normal wireless n standard.
p3rad0x
Long time Member
Long time Member
Tue Feb 06, 2018 9:59 am
Looks like the wireless card died,
The sxt qlite5 will work you just need to set the band to 5Ghz only N and not AC
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
vaah
Tue Feb 20, 2018 11:14 am
Yeah looks like it. I did netinstall a few times. And the other day i was getting some ssid popped up when i scan the wireless. But it wont connect. After a reboot, it was back to nothing again.
So i ended up buying the sxtsq 5AC. The connection has been doing fine so far. Hopefully my other sxt sa5ac doesnt die like this.
I'm gonna ask around to see if the service center is able to repair it.
Sent from my SM-N910H using Tapatalk
Users browsing this forum: maungmaungmyatsan and 25 guests
