christianrodher
SXTsq G5acD max real throughput?
Sun Feb 18, 2018 11:15 pm
ptp link is like 200m. The max throughput I'm able to get is 160mb of 400mb bandwidth available. Has anyone achieved higher?
link status
Strength -53/-53 dBm
ccq 93/88 %
signal to noise 55 dB
protocol nstreme
this is my configuration
PTP BRIDGE AP
# feb/18/2018 16:33:56 by RouterOS 6.42rc28
# software id =
# model = RouterBOARD SXTsq G-5acD
# serial number =
add name=AP-bridge
set [ find default-name=ether1 ] mac-address=XX:XX:XX:XX:XX:XX
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee \
    country=XXXX disabled=no frequency=XXXX frequency-mode==superchannel mode=\
    bridge name=wlan2 ssid=XXXXXX tx-power=13 tx-power-mode=\
    all-rates-fixed wds-default-bridge=AP-bridge wds-mode=dynamic \
    wireless-protocol=nstreme
/interface wireless nstreme
set wlan2 enable-nstreme=yes framer-policy=best-fit
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXX \
    wpa2-pre-shared-key=XXXXX
/ip hotspot profile
/port
set 0 name=serial0
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=AP-bridge hw=no interface=ether1
add bridge=AP-bridge interface=*1
add bridge=AP-bridge interface=wlan2
add interface=ether1 list=WAN
add interface=wlan2 list=LAN
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=AP-bridge
/ip dns static
add address=192.168.88.1 name=router.lan
/system clock
set time-zone-name=America/XXXXX
/system identity
set name=Mikrotik-AP
/system package update
set channel=release-candidate
/system routerboard settings
set silent-boot=no
PTP-CPE-BRIDGE
# feb/18/2018 16:48:50 by RouterOS 6.42rc28
# software id =
# serial number =
add name=cpe-bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
    country=XXXX disabled=no frequency-mode=superchannel mode=station-bridge \
    ssid=ptp-wifast-jowy tx-power=13 tx-power-mode=all-rates-fixed \
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
    unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=XXXX \
    wpa2-pre-shared-key=XXXXxxx
/ip hotspot profile
/port
set 0 name=serial0
add bridge=cpe-bridge interface=wlan1
add bridge=cpe-bridge hw=no interface=ether1
set discover-interface-list=all
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=cpe-bridge
/ip dns static
/system clock
/system identity
set name=MikroTik-CPE
set silent-boot=no
marcin21
Re: SXTsq G5acD max real throughput?
Mon Feb 19, 2018 12:16 am
switch wireless protocol to 802.11
christianrodher
Mon Feb 19, 2018 4:43 am
in 802.11 i only get about 20mbs.... what could be wrong?
vaah
Mon Feb 19, 2018 6:37 am
i have sxt SA5AC connected to SXTsq 5AC creating a PTP connection with a distance of 300m, getting only 20mbps when using nstreme, then i switched to 802.11. To my surprise i get 300mbps RX, 400mbps TX. not sure why i don't get the same rate both direction. I'm pretty happy with the 802.11 result. so i ditched the nstreme set up. nv2 even worse, kept getting drop-out.
christianrodher
Mon Feb 19, 2018 1:42 pm
I mean the real throughtput... not what the registration say.
Mine say 650mb both ways.....
But a speed test wont go over 160mb in nstreme and 20-30 in 802.11. I have 400mb bandwidth.
haik01
Mon Feb 19, 2018 11:36 pm
How do you test the bandwidth? What equipment? What processor in the test equipment does the down / upload?
christianrodher
Tue Feb 20, 2018 12:27 am
i test the bandwidth in www.speedtest.net. I test it in my pc AMD FX 6300 3.5ghz (six core cpu).
with Ethernet cable from router/modem connected to PC i get 340-380 mbs.
in my other house with the ptp bridge i get around 160mbs tops.
vaah
Tue Feb 20, 2018 6:53 am
yes, this is the real throughput using bandwidth test, but I haven't actually transfered big file thru this link yet. The real real speed may be not as show with btest. I'll report back when I have result. In my case as stated before nstreme protocol even worse. My registration status from station bridge side says 866mbps which is max iirc.
Kliwer
Thu Feb 22, 2018 10:14 am
My tests from yesterday (80MHz, room test, iperf3 tcp, 6.42rc30)
1. nstreme - stable 180Mbps - it seems it's max for nstreme regardless of device
2. nv2 - unstable, max that I seen was about 300Mbps
3. any - unstable too, max that I seen was about 550Mbps
It looks that MT is on a good road, but still there is a lot of work.
honzam
Thu Feb 22, 2018 11:03 am
Can anyone make an outdoor P2P test with 20Mhz channel? Thanks
LAN, FTTx, Wireless. ISP operator
vaah
Thu Feb 22, 2018 11:45 am
what's the distance between devices?
Kliwer
Thu Feb 22, 2018 11:56 am
Less than 2m.
christianrodher
Fri Feb 23, 2018 2:14 pm
changing manual tx power to 13 to get a signal of -52-53 was the problem....
exact same configuration swithing tx power to default (-38-38 signal) give me max throughput... Now i get extactly the same speed from the ptp than if i do the speedtest by ethernet cable from modem.
how do i keep the speed, but fix the signal to a normal lvl?
Users browsing this forum: mrmut, passt, slav0nic and 24 guests
