kunago
CAPsMAN with VLAN not working properly
Sun Mar 18, 2018 10:28 am
What I am trying to achieve and failing to do so is to have a DHCP server that would serve IPs to my LAN and to CAPsMAN clients while being in a single VLAN. All clients in this VLAN should be able to reach each other while isolated from other VLANs.
So far I was able to make it work for CAPsMAN only. With the following setup my CAPsMAN clients properly receive IPs and receive VLAN tag, while it does not work for LAN clients. Those are unreachable by any means, do not receive an IP address from DHCP server. I tried to have the LAN clients to connect directly to Mikrotik where I have the DHCP server but it does not seem to work. Those interfaces I am connecting to are in bridge and that bridge has a VLAN interface.
Could someone please help?
add fast-forward=no name="bridge company"
add fast-forward=no name="bridge company host"
set [ find default-name=ether1 ] name=ether01
set [ find default-name=ether2 ] name=ether02
set [ find default-name=ether3 ] name=ether03
set [ find default-name=ether4 ] name=ether04
set [ find default-name=ether5 ] name=ether05
set [ find default-name=ether6 ] name=ether06
set [ find default-name=ether7 ] name=ether07
set [ find default-name=ether8 ] name=ether08
set [ find default-name=ether9 ] name=ether09
set [ find default-name=ether10 ] poe-out=off
set [ find default-name=sfp1 ] name=sfp
/interface vlan
add interface="bridge company" name="VLAN company" vlan-id=8
add interface="bridge company host" name="VLAN company host" vlan-id=10
add address=172.27.8.1/23 interface="VLAN company" network=172.27.8.0
add address=172.27.10.1/24 interface="VLAN company host" network=172.27.10.0
/caps-man datapath
add bridge="bridge company" client-to-client-forwarding=yes local-forwarding=no vlan-id=8 vlan-mode=use-tag name=company
add bridge="bridge company host" client-to-client-forwarding=no local-forwarding=no vlan-id=10 vlan-mode=use-tag name="company host"
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn identity-regexp=wifi1 master-configuration="2,4 GHz company" name-format=identity slave-configurations="2,4 GHz company slave - host"
add action=create-dynamic-enabled hw-supported-modes=gn identity-regexp=wifi2 master-configuration="2,4 GHz company" name-format=identity slave-configurations="2,4 GHz company slave - host"
add bridge="bridge company" hw=no interface=ether03
add bridge="bridge company" hw=no interface=ether04
add bridge="bridge company" hw=no interface=ether05
add bridge="bridge company" hw=no interface=ether06
add bridge="bridge company" hw=no interface=ether07
add bridge="bridge company" interface=ether08
add bridge="bridge company" hw=no interface=ether09
add bridge="bridge company" hw=no interface=ether10
add bridge="bridge company" hw=no interface=sfp
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes
/ip dhcp-client
add default-route-distance=21 dhcp-options=hostname,clientid disabled=no interface=ether01 use-peer-dns=no use-peer-ntp=no
add add-arp=yes address-pool="pool company" authoritative=after-2sec-delay disabled=no interface="VLAN company" lease-time=8h name="dhcp company"
add add-arp=yes address-pool="pool company host" authoritative=after-2sec-delay disabled=no interface="VLAN company host" lease-time=2h name="dhcp company host"
add address=172.27.8.0/23 dns-server=172.27.8.1 gateway=172.27.8.1 netmask=23
add address=172.27.10.0/24 dns-server=172.27.10.1 gateway=172.27.10.1 netmask=24
add name="pool company" ranges=172.27.9.64/27
add name="pool company host" ranges=172.27.10.64/27
lendy
Re: CAPsMAN with VLAN not working properly
Fri May 29, 2020 1:26 pm
did you find a solution for this? I have exactly the same issue...
Thank you
anav
Fri May 29, 2020 10:13 pm
did you try it without setting ip firewall =yes. Its not usual to apply this on vlans (by that I mean on the bridge , most just use the firewall filter rules.....)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
alexanwar
Tue Jun 02, 2020 1:01 pm
since you're using capsman forwarding and it works on your wifi clients, i think your capsman config is correct, the issue is not on the capsman but on the vlan passing between bridges.
on your config:
/interface vlan
since you're using "bridge company" as trunk port, all the vlan must be set on it, like this:
/interface vlan
add interface="bridge company" name="VLAN company host" vlan-id=10
this will make all ports assigned to "bridge company" to act as trunk port so you can plug it on any port. this useful if you have multiple device to be attached.
then attach the vlan to the proper bridge:
add bridge="bridge company" interface="VLAN company host"
this will link the bridge and the vlan.
the dhcp server and ip address should be set to the bridge instead to the vlan interface, like this:
add address=172.27.8.1/23 interface="bridge company" network=172.27.8.0
add address=172.27.10.1/24 interface="bridge company host" network=172.27.10.0
add add-arp=yes address-pool="pool company" authoritative=after-2sec-delay disabled=no interface="bridge company" lease-time=8h name="dhcp company"
add add-arp=yes address-pool="pool company host" authoritative=after-2sec-delay disabled=no interface="bridge company host" lease-time=2h name="dhcp company host"
make sure you disable vlan filtering on the all bridge settings too.
for capsman forwarding, you don't need to use vlan tag in the datapath, so optionally you can later it like this:
/caps-man datapath
do the same on the other devices.
this will link your wifi client and lan/ethernet client on the same bridge so it become one broadcast domain.
for better performance, activate hardware offload on the bridge port and disable use ip firewall on the bridge settings.
mkx
Tue Jun 02, 2020 5:02 pm
/interface vlan
Correct.
Wrong! The VLAN interface (or rather its tagged end) is already part of "bridge company" and one should never add both ends of VLAN interface to same bridge.
Due to error made in the previously quoted code, this is wrong again. And the rest of the post is wrong as well ... if one is using VLANs on bridge, then vlan-filtering should be enabled.
Really, read this tutorial to understand how VLANs should be done in ROS.
If one wants to use HW offload for VLAN-enabled networking, then config is different (and previous post is not accurate at all for that kind of setup as well).
BR,
Metod
alexanwar
Wed Jun 03, 2020 12:36 am
/interface vlan
Correct.
thanks for pointing out, i just realize that i made a typo. it should be:
add bridge="bridge company host" interface="VLAN company host"
instead :P
it works, but as you said, it's not a best practice. so, do you have any suggestion on this issue? i'm interest to learn & fix my mistake too :)
mkx
Wed Jun 03, 2020 8:50 am
I posted a link to a fine tutorial which gives good insight into the recommended practice of doing VLANs in ROS.
BR,
Metod
alexanwar
Wed Jun 03, 2020 10:01 am
i used that method on 1100 and 4011 since the cpu is strong enough to handle the traffic, but on 750 or 951 it bang the cpu to 100% on lan traffic since no hardware offload can be enabled. the trick i made maybe not a best practice but at least it can let hardware offload enabled on the primary bridge.
well then, i'll try to find a way to enable hardware offload to work on the scenario of this topic ;)
mkx
Wed Jun 03, 2020 11:16 am
If one wants to have VLANs HW offloaded, then one should use the old way to configure it. Basic VLAN philosophy is same regardless where VLANs are configured (on bridge or on switch chip), only configuration commands are different. For old school there's manual page, which covers VLANs for ether ports. One has to slightly change configuration of other bridged interfaces (e.g. wlan interfaces) ... and layers above L2 (VLAN interfaces, IP,...) are exactly the same either way.
Beware that not all Routerboard devices are capable of HW offloaded VLANs, only devices with switch chips can do it ... and not even all of those, for example RB4011 and RB750Gr4 are out of this scope.
BR,
Metod
alexanwar
Wed Jun 03, 2020 1:04 pm
yes, device with multiple switch chip like 4011 and 1100ah4x may cause headache also. i guess it's better to use layer 3 switch if wirespeed is needed, router only for wan & outgoing traffic only.
still miss the old days way when routeros still support master/slave port :D
Users browsing this forum: Google [Bot] and 55 guests
