I got one of these cheap off of ebay ~ $50 or so. I read how mikrotik had a steeper learning curve than other similar devices. But I've been a sysadmin for 10 years, so I figured I would be able to figure it out.
But an hour in and I have made zero progress to even get as far as winbox. Turning it on and I never see a wireless lan called Mikrotik come across at all and the lights for 5/2.4/CAP never come on. If I plug into my router, I do see the ETH led briefly, but it goes out. And it never shows up in the device list on the router.
I went ahead and used netinstall to reinstall the firmware (routeros-mipsbe-6.41.3.npk) and that worked with zero issues. According to the seller this was pulled out of a working environment, using it as a WISP AP.
The seller thought it would be a good idea for me to post on these forums.
