MUM Europe 2020
tucsy
CAPsMAN VLAN question
Sat Mar 31, 2018 8:28 pm
I would like to ask some help because I'm really confused.
I tried to make some VLANs and SSIDs in Mikrotik devices (router and AP with CAPsMAN).
In CAPsMAN I set VLAN mode to "use tag" and VLAN ID to "100" but on the AP I see "no tag" and VLAN 1.
I attached two sreenshots too.
Does anyone have an idea of what's wrong?
tucsy
Re: CAPsMAN VLAN question
Fri Apr 06, 2018 6:36 pm
Does someone have any idea? :)
dasiu
Trainer
Trainer
Re: CAPsMAN VLAN question  [SOLVED]
Mon Apr 09, 2018 3:46 pm
Your check is wrong :). When a wireless interface on a MikroTik is managed by CAPsMAN, the interface is not showing you the running settings. They can be seen on the CAPsMAN on the interface, only there.
tucsy
Sun Apr 15, 2018 1:32 pm
Thanks. :D :)
Users browsing this forum: 2jarek, MSN [Bot] and 22 guests
