gmeden
dynadish license transfer
Mon Apr 09, 2018 9:29 pm
Tower was hit by lightning , lost the lan connection to 3 dynadishes. Is it possible to transfer the license (using the mac address of the defective units) to retrieve the licenses to install on newly purchased replacements?
jarda
Re: dynadish license transfer
Mon Apr 09, 2018 9:41 pm
New devices are already equipped with the license. Nothing to transfer...
gmeden
Tue Apr 10, 2018 6:39 am
lvl 3 ... I need lvl 4 to transfer
strods
Tue Apr 10, 2018 8:31 am
RouterBOARD licenses are not transferable. You can consider included RouterOS license within a product as a free gift which can not be used on any other equipment.
pepek
Tue Apr 10, 2018 9:09 am
He is not talking about build in L3 license but about separately bought additional L4 license...
gmeden
Tue Apr 10, 2018 3:10 pm
Yeah , well those lvl 4 licenses were not free. I had to pay for them , so no gratuity involved...
TomjNorthIdaho
Forum Veteran
Forum Veteran
Tue Apr 10, 2018 3:55 pm
Be grateful that that's all you lost in a direct lightning strike.
I've had direct lightning strikes where I've burnt up ...
- dozens of ethernet surge supressors
- generator -and- transfer switch
- switches
- tower enviornmental & security system
- dozens of POE power supplies
And the worst of it all is I whitnissed all of the above turn to black smoke during one single lightning strike when I was driving by during a thunder storm.
You can't really do much to prevent direct lighting strikes - however you can have ready-to-go plans for what to do when bad stuff happens.
Note - If the voltage is enough to arc several thousand feet from the sky to your tower , then it can easily get past your lightning rod , jump/melt your surge supressors and fry anything connected by wire in any possible path to earth ground.
North Idaho Tom Jones
gmeden
Tue Apr 17, 2018 11:19 pm
Yep Tom, 3 towers hit ....lost 10 radios , 4 managed switches , and a core router...spring has sprung....but I still believe that if you purchased a lvl 4 license for a device , and that device is rendered useless , then you ought to be able to transfer that license to another device , after all , you paid for it. If it were my company , you could...
Users browsing this forum: No registered users and 42 guests
