MUM Europe 2020
Mudz
Best Mikrotik PTP Wireless System carrying 10 units 4mp cctv cameras distance for PTP is 1km
Thu Apr 19, 2018 10:46 am
Good day mikrotik enthusiast, I am asking for you help and ideas that what would be the best mirotik wireless system to be used for I will be carrying 10 units of cctv 4mp cameras with the distance of more or less 1km?
I do appreciate your responce thank you :)
Mudzramer A. Hayudini
MikroTik Certified Academy Instructor
mlenhart
Re: Best Mikrotik PTP Wireless System carrying 10 units 4mp cctv cameras distance for PTP is 1km
Thu Apr 19, 2018 10:59 am
Which band? 2 GHz or 5?
What is the noise level?
Are you limited somehow? Price, dimensions, power consumption...
What is your expectations for bandwidth?
Mudz
Thu Apr 19, 2018 11:15 am
5ghz, as long as cameras can be carried. but probably low cost mikrotik wireless
mlenhart
Thu Apr 19, 2018 11:24 am
if you are in a low noise location, go for any SXT...
Mudz
Thu Apr 19, 2018 11:31 am
so, can I have the assurance for SXT SQ 5 AC to carry all these 10 units of cctv without any problems for monitoring? for we tried using ubnt powerbeam ac but basing from the output, best result is upto 8 cameras only. Thanks in advance
mlenhart
Thu Apr 19, 2018 11:35 am
no one will give you any assurance.
We do not know your environment, your bandwidth requirements, your noise levels, configuration...
If you need any assurance, hire a MikroTik certified consultant in your country.
Mudz
Thu Apr 19, 2018 11:36 am
the area is open, since it is on the mountain top
Mudz
Thu Apr 19, 2018 11:37 am
less noise since no other radios are installed on the area
mbfound
Thu Apr 19, 2018 11:40 am
What model of Powerbeam? Sounds more like you didn't tune the link correctly. We have a normal Powerbeam M5 40Mhz link that does 80Mbits (+ambient upload traffic).
What is the bitrates per camera stream?
mkx
Sat Apr 21, 2018 5:07 pm
OP mentioned 4mp ... which is twice HD (not 4K!). With poorly encoded video (when camera's CPU is not up to its job) single video stream can easily exceed 20Mbps in moments of "intense action". OP mentioned 10 such devices, if not all of them get "action" at the same time, then perhaps he could get by with 150Mbps link. Not an easy task I guess.
BR,
Metod
vladimirslk
Sun Apr 22, 2018 12:58 pm
1km on ac 5ghz 150 will not be an issue..
surendranraje
Sun Apr 22, 2018 6:06 pm
4mp camera resolution plz change to 720p and ptp signal range 60 to 68 he is the good signal strength I have using the sxt ptp 1.3 or 4 mp camera 60 numbers remote side normally run
surendranraje
Sun Apr 22, 2018 6:22 pm
thanks
Users browsing this forum: No registered users and 26 guests
