todayheads
Wireless PTMP Dilemma
Sat Apr 21, 2018 2:12 am
ok, This image somehow describes my problem.
I have the network working on bridge1, we use PPPoE accounts with mac address lock, the problem I need to give the two stations connected to SXTsq AP same PPPoE account.how can that be done
I already tried the following but with no success
1- removed ether 6 from bridge1 and still used as master port= none ( where PPPoE account on AP added)
2-tried to add the account to ether 6 but with no success
3-tried to add the account to ether 6after adding ether6 to bridge1 in ports
4-tried to make DHCP server and client with no success
How can that be achieved, it is driving me nuts
mistry7
Re: Wireless PTMP Dilemma
Sat Apr 21, 2018 7:14 am
This to stations needs to share the same PPPoE?
Please post you configuration export
mbfound
Sat Apr 21, 2018 10:28 pm
Are the IPs the PPPoE server give you the static or dynamic? If its dynamic, you could just duplicate the setup.
todayheads
Sun Apr 22, 2018 1:01 am
hi guys
thanks for the reply
its dynamic IPs, the problem is the only way to send traffic is by adding a router, put the PPPoE account, attach the AP to the LAN in and then transmit connection to stations wirelessly
why it is not working with Mikrotik, there must be a way to do that as RB-2011 has huge potential for networking magic
dravnieks
Tue May 01, 2018 2:05 pm
By your description I still have no Idea what do you want to achieve? 1st thing is why do you want to use the same pppoe account in 2 locations?
pe1chl
Tue May 01, 2018 2:26 pm
Such a setup will only work when the links are transparent for MAC addresses, which such a PtMP WiFi network normally isn't.
It will work when you configure the WiFi mode as bridge (and station-bridge).
Users browsing this forum: No registered users and 36 guests
