krystian
RB962UiGS-5HacT2HnT hAP ac capacity problem
Mon May 28, 2018 3:38 pm
Hello
I have a RouterBoard RB962UiGS-5HacT2HnT hAP ac and I have wireless capacity problem.
I have WAN 100 Mbit/s and MacBook Pro 13 2017.
All is 5GHz connection and in registration I see 866 mbps... but I have only 70 Mbit/s WAN speed MAX.
What can be a problem?
Channel width I have 20/40/80 MHz Ceee but in wireless settings I see Channel 5180/20-Ceee/ac/P.
Please help me fix this problem.
I have current version RouterOS.
jarda
Re: RB962UiGS-5HacT2HnT hAP ac capacity problem
Mon May 28, 2018 4:38 pm
What tools / profile shows?
eddieb
Mon May 28, 2018 4:46 pm
registration does not mean actual wireless speed. it might be a lot less ...
Test your connection speed with http://www.dslreports.com/speedtest
And show us your config
krystian
Mon May 28, 2018 5:56 pm
My wireless config https://postimg.cc/gallery/1l93b0w1o/
DSL reports I have about 78 Mbit/s
krystian
Tue May 29, 2018 9:53 am
So where is a problem?
eddieb
Tue May 29, 2018 10:23 am
please post an export of your config.
please use a wired connection and retry dslreports
what are your wireless conditions ? distance ? number of walls ? type of walls ? number of active clients ?
krystian
Tue May 29, 2018 10:35 am
Wired connection has 100 Mbit/s no problem.
I have empty freq 5GHz about my home - 0 walls and router 2 meters to my MacBook Pro 13 2017.
I'm only active client.
My configuration https://postimg.cc/gallery/1l93b0w1o/
eddieb
Tue May 29, 2018 10:38 am
Sorry, that is not an export, please post the output of "export hide-sensitive"
krystian
Tue May 29, 2018 10:44 am
Ok but I can do about 5 pm.
I have default configuration wifi 20/40/80 MHz Ceee.
I don't know why is this problem.
This model Mikrotik will be no problem 200-300 Mbit/s 5GHz yes?
2 meters to router.
grusu
Tue May 29, 2018 11:01 am
2 meters to router.
If you did the test between your computer and a WAN site you are limited by the 100 Mbps WAN connection.
Make a test between the computer connected to the wireless and another cable connected to 1GB in the LAN.
krystian
Tue May 29, 2018 11:16 am
I haven't other 1Gbit hardware.
But i need capacity to my computer :)
About 70Mbit/s is max speed on this model Mikrotik?
normis
Tue May 29, 2018 11:17 am
We have tested 700Mbit between two Macbook Pro computers, through this router. We used iperf3 for testing.
krystian
Tue May 29, 2018 11:22 am
So where Can I have problem?
I have 100 Mbit/s WAN and wired connection no problem... and 5GHz a/c 70 Mbit/s only... I see "registration" in MT 500-866 Mbit/s.
Maybe must I set any in MT configuration?
normis
Tue May 29, 2018 11:32 am
How did you get that speed? Try iperf3 between two computers, instead of simple file copy.
krystian
Tue May 29, 2018 11:35 am
I don't have other 1Gbit computer.
But WAN speed (5GHz wifi use) to my computer should be 100 Mbit/s no problem... I don't know why is only 70 Mbit.
normis
Like I asked, how did you test this 70Mbit?
krystian
Tue May 29, 2018 11:37 am
I'm connect to router 5GHz ac wifi and i get a file my ISP speedtest and dslreports too.
Wired I have 100 Mbit/s no problem but wifi is max about 70Mbit/s.
normis
Tue May 29, 2018 11:46 am
This is not a reliable way to test anything, but in any case, make a screenshot of the connection information in wireless "registration table" when you do this speedtest. So we can see the signal and noise data.
krystian
Tue May 29, 2018 11:48 am
Ok I do it about 5pm.
I does it yesterday and i had about 500 Mbit remember...
krystian
Tue May 29, 2018 8:13 pm
Ok please look: https://postimg.cc/gallery/gp0j4kvw/
krystian
Wed May 30, 2018 8:22 am
Normis help me please :) I think whether to change the router for another one...
I can give You access to my Mikrotik and can You look?
Maybe this is problem Mikrotik with Apple devices?
normis
Wed May 30, 2018 9:36 am
Like I said, we have no problem to get 700Mbit with Apple Macbook and here is the result from an iPhone and the same router (my download speed is limited in the router):
Like I said, your speed is limited by the internet connection. To test the router WiFI speed, you must test between two laptops, not using some kind of Speedtest. Your WAN is only 100Mbit or less.
krystian
Wed May 30, 2018 9:38 am
I know but wired connection I have 100 Mbit/s no problem.
Wireless I have to about 70 Mbit/s max.
normis
Wed May 30, 2018 9:42 am
Let me know when you have tried other testing methods, like suggested.
Users browsing this forum: Bing [Bot] and 101 guests
