russman
60Ghz 6.42.3 Bug Report
Wed Jun 06, 2018 7:57 pm
When you export file on the master/ap, the export doesn't contain the SSID but it does contain the reset including the frequency and password, when you export file on the slave/stations it contains the SSID. You can manually enter the SSID into the exported file for the AP and load that without errors and it works.
antonsb
Re: 60Ghz 6.42.3 Bug Report
Thu Jun 07, 2018 10:29 am
thank You for reporting this, we will look into it.
Users browsing this forum: No registered users and 39 guests
