aldoir
CAPsMAN unable to manage its own Wireless interface
Tue Jun 12, 2018 4:54 am
I'm trying to setup a CAPsMAN, configured the controller (RB2011) and the first CAP client (RB951Ui)
The client connects fine and is provisioned as expected
01:21:02 caps,info CAP selected CAPsMAN RB2011 (D4:CA:6D:62:FC:XX/11/0)
01:21:05 caps,info CAP connected to RB2011 (D4:CA:6D:62:FC:XX/11/0)
01:21:05 caps,info CAP joined RB2011 (D4:CA:6D:62:FC:XX/11/0)
But when I try to setup the controller's own wireless interface, I get this message:
jun/11 22:44:54 caps,info CAP selected CAPsMAN RB2011 (::ffff:172.16.1.1:5246)
jun/11 22:45:14 caps,info CAP connect to RB2011 (::ffff:172.16.1.1:5246) failed: timeout
Tried to disable all filter rules, no luck
Tried to manually specify the "CAPsMAN Addresses: 127.0.0.1" no luck, it still tries to connect to this address "::ffff:172.16.1.1"
How can I ensure it will connect using layer2 like the other client?
Quaziee
Re: CAPsMAN unable to manage its own Wireless interface
Tue Jun 12, 2018 5:42 am
add action=accept chain=output dst-address=127.0.0.1 port=5246,5247 protocol=\
udp src-address=127.0.0.1
add action=accept chain=input dst-address=127.0.0.1 port=5246,5247 protocol=\
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1
Sent from my LG-LS777 using Tapatalk
aldoir
Tue Jun 12, 2018 5:23 pm
Didn't work:
[admin@RB2011] /ip firewall filter> print terse
 0    comment=CAP chain=output action=accept protocol=udp src-address=127.0.0.1 dst-address=127.0.0.1 port=5246,5247 log=no log-prefix=""
 1    comment=CAP chain=input action=accept protocol=udp src-address=127.0.0.1 dst-address=127.0.0.1 port=5246,5247 log=no log-prefix=""
[admin@RB2011] /interface wireless cap> print
                            enabled: yes
                         interfaces: wlan
                        certificate: none
                   lock-to-caps-man: no
               discovery-interfaces:
                 caps-man-addresses: 127.0.0.1
                     caps-man-names:
  caps-man-certificate-common-names:
                             bridge: bridge-local
                     static-virtual: no
11:21:59 caps,debug CAP discovery target list:
11:21:59 caps,debug   ::ffff:127.0.0.1:5246
11:22:02 caps,debug CAP discovery over, no results
11:22:02 caps,debug CAP Discover->Select
11:22:02 caps,debug CAP did not find suitable CAPsMAN
11:22:02 caps,debug CAP Select->Sulking
I can see the connection on /ip firewall connections, but it still is unable to connect/provision.
Quaziee
Wed Jun 13, 2018 3:43 am
How do you have them provisioned? Based on mac or Default 00.00.00.00.00.00? And have you tried to reboot after changing setting? Also might want to move firewall to the top of the list.
David Huizenga
uldis
Wed Jun 13, 2018 10:15 am
you can add the log=yes option for the drop rules to see if the CAP connections are dropped by the firewall or not.
nickshore
Wed Jun 13, 2018 4:13 pm
You don't seem to have a discovery interface selected, probably because you are trying a layer3 connection.
I use:
/interface wireless cap set discovery-interfaces=bridge1 enabled=yes interfaces=wlan1
In your case it is probably bridge-local, and remove the capsman IP, then it will use L2 to find the capsman
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
aldoir
Wed Jun 13, 2018 4:32 pm
David Huizenga
Provisioned with detault 00:00:00:00:00:00 mac address.
Remember: I have two other RB951Ui on the same network working fine. My only problem is the local interface
Both rules are IDs 0 and 1 (topmost of the list)
Thanks for your help
aldoir
Wed Jun 13, 2018 4:39 pm
I will add the logging, but my only drop rules are based on WAN interfaces.
As you can see on the attached image, the connection is estabilished, but for some reason it's not provisioned
aldoir
Wed Jun 13, 2018 4:43 pm
I use:
This was my first attempt, but it still does L3
                            enabled: yes
                         interfaces: wlan
                        certificate: none
               discovery-interfaces: bridge-local
                 caps-man-addresses:
                     caps-man-names:
                     static-virtual: no
And the corresponding log
10:36:56 system,info CAP configuration changed by admin
10:36:58 caps,info CAP selected CAPsMAN RB2011 (::ffff:172.16.1.1:5246)
10:37:18 caps,info CAP connect to RB2011 (::ffff:172.16.1.1:5246) failed: timeout
10:37:18 caps,info CAP failed to join RB2011 (::ffff:172.16.1.1:5246)
On other devices on the same network it does L2 as expected
13:19:00 caps,info CAP selected CAPsMAN RB2011 (D4:CA:6D:62:FC:XX/11/0)
13:19:03 caps,info CAP connected to RB2011 (D4:CA:6D:62:FC:XX/11/0)
13:19:03 caps,info CAP joined RB2011 (D4:CA:6D:62:FC:XX/11/0)
nickshore
Wed Jun 13, 2018 6:04 pm
Did you make sure the interface was removed from capsman ?
The only time it should be doing it by IP is if you specify the IP of the capsman when setting up the cap.
aldoir
Wed Jun 13, 2018 7:25 pm
You mean from Manager > Interfaces or Bridge > Ports?
[admin@RB2011] /caps-man manager interface> print
Flags: * - default, X - disabled, D - dynamic
 #     INTERFACE        FORBID
 0 *   all        yes
 1     bridge-local                                                              no
the wlan interface is not assigned to the bridge-local bridge
aldoir
Thu Jun 14, 2018 8:35 pm
[admin@RB2011-ESCRITORIO] /caps-man manager interface> print
 #     INTERFACE        FORBID
 0 *   all        no
If I allow connections on all interfaces it does work, still thru L3
[admin@RB2011] /caps-man remote-cap> print brief
 # ADDRESS                                                NAME     STATE         RADIOS
 0 4C:5E:0C:F2:6B:XX/55937                                [4C:5... Run                1
 1 172.16.1.1/50917                                       [D4:C... Run                1
 2 4C:5E:0C:F4:A1:XX/52692                                [4C:5... Run
IMHO this is a bug.
MockTurtle
Fri Jun 15, 2018 11:03 pm
any luck? i'm in the same situation.
the client cap (cap ac) register fine but the only way i can get the on board (rb751g) to show up when setting forbid=no.
i *think* i got this working before... but yesterday i upgraded to 6.42.3....
evilworm
Mon Jul 16, 2018 3:13 pm
same bug ... have 3 mikrotik devices (hap ac, 6.42.6) - two of them connects to capsman without issues but the local cap->capsman does not work
edit:
this seems to have solved the issue for me: viewtopic.php?t=127517
MockTurtle
Tue Aug 14, 2018 11:33 pm
doesn't solve it for me. i've disabled all my filter rules. no bueno.
the only way for capsman to "see" the onboard wlan is to set forbid all to no in caps manager.
jrbenito
Mon Jan 21, 2019 4:54 pm
Same here, added firewall rule and had to set forbid to no on all. For me this is a bug because someone upstream (wan) may try connect your CAPsMan (or at least know you are running it).
I think it would be logical to forbid CAPsman on all interfaces and allow it on some interfaces (especially if you only have caps comming through a single ethernet port)
gotsprings
Forum Veteran
Forum Veteran
Mon Jan 28, 2019 4:09 pm
Had this working for several months now.
hAP AC2 is the main router and I wanted to add it to the cap config that it is running three cAP AC.
set certificate=request discovery-interfaces=bridge enabled=yes interfaces=wlan1,wlan2
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Users browsing this forum: didomir, kswong and 21 guests
