sergeymikrotikov
Network File Sharing problemt
Sun Jun 17, 2018 3:04 pm
Dear All
I have to ask you for a help. I have hit the problem which I can not resolve for several days.
I have got home network of seversl PCs running on Windows 7 64.
One of them is SERVER. Router - Mikrotik.
Several days ago I have suddenly lost access to shared printer and shared folders on SERVER (Error code 0x80070035 - The network path not found).
From my workstation I still can ping SERVER, I can log into SERVER via Remote Desktop, I can connect to Database or Webserver on SERVER.
So I guess it is not networking proble but rather internal server configuration.
While logged into SERVER (RD) I still can NOT open my share: \\SERVER\Shared however I can open it via : \\localhost\Shared.
It is not Mikrotik problem. I have replaced it with my old TP-LINK and seeing same problem;
Anyone can help how to resolve\diagnose this problem?
Thanks in advance
Sergey
2frogs
Long time Member
Long time Member
Re: Network File Sharing problemt
Sun Jun 17, 2018 4:36 pm
Check to see if your network connection type is still Home.
http://www.dummies.com/computers/operat ... windows-7/
sergeymikrotikov
Sun Jun 17, 2018 9:20 pm
Yes, my network is Home network (on all PCs).
I performed diagnostics on Incoming connections and looks like something blocking them:
Security policy settings or firewall settings on this computer might be blocking the connection.
I have switched off Firewall. But I have no idea what to do with security settings.
sergeymikrotikov
Wed Jun 20, 2018 10:10 pm
I am still fighting with the issue.
What I could find is that port 445 is blocked on server.
I have diagnosed it with portqry:
Starting portqry.exe -n hippy -e 445 -p TCP ...
Querying target system called:
hippy
Attempting to resolve name to IP address...
Name resolved to 192.168.0.151
querying...
TCP port 445 (microsoft-ds service): FILTERED
portqry.exe -n hippy -e 445 -p TCP exits with return code 0x00000002.
Anyone can help with idea what may be blocking the port.
I have switched firewall off. But port is still blocked.
Sergey
mistry7
Wed Jun 20, 2018 10:45 pm
user ip address when it is routed
sergeymikrotikov
Wed Jun 20, 2018 10:48 pm
Sorry, did not get you
sergeymikrotikov
Fri Jun 22, 2018 3:28 pm
By the way I have solved the problem.
Luckily I have noticed that windows by itself installed Critical Security Update 13th of June.
Normally I do not updated windows on my server.
I have rolled back to the restore point before 13th and now everything works fine as before.
Users browsing this forum: No registered users and 18 guests
