joserudi
5 GHz, 3x30° HD Sector Antenna
Thu Jun 21, 2018 8:09 am
I need to locate several antennas at the same point with a high density of clients. Have you tried the new 5 GHz, 3x30 ° HD Sector Antenna from Ubiquiti with netmetal equipment? I think it could turn out very well.
mistry7
Re: 5 GHz, 3x30° HD Sector Antenna
Sat Jun 23, 2018 2:57 am
Take a look at RF Elements Horns
chechito
Sat Jun 23, 2018 7:01 am
yeah better option
joserudi
Tue Jun 26, 2018 8:08 pm
What a great news, I see some symmetrical novelty that I do not understand very well. What do you recommend the 30º, 60º, 70º, 80 or 90º. Have you tried any?
honzam
Tue Jun 26, 2018 8:54 pm
If you need to cover the 30 degree angle, then use 30º. Yes we use all 30 - 90º
LAN, FTTx, Wireless. ISP operator
joserudi
Wed Jun 27, 2018 11:52 am
Thanks, I see that there are several Twisport adapters but I do not see any specific for netmetal or netbox. Which you use to adapt the mikrotik euqipos to the horn antennas rf elements
honzam
Wed Jun 27, 2018 2:31 pm
For Mikrotik is now only this - https://rfelements.com/products/wireles ... terboardtm
You can use it with rb912 or rb922. It works wery well
chechito
Thu Jun 28, 2018 8:57 am
i think the best way to do it is 30°
this webinar explains many path to migrate correctly
miochoice
Thu Aug 02, 2018 12:23 am
Using RF elements 30 horns and was one of the best investment i ever did , we operate in very noisy environment and they work beautifully
Users browsing this forum: No registered users and 22 guests
