You are maxing out the CPU as it is not strong enough to generate the traffic and also pass it. And that bandwidth test only runs on a single core on multi-core CPU’s. Use iperf between 2 pc’s instead.
TX Sector info shows. that you can align it better....Tnx mateYou are maxing out the CPU as it is not strong enough to generate the traffic and also pass it. And that bandwidth test only runs on a single core on multi-core CPU’s. Use iperf between 2 pc’s instead.
It is a known fact. Mikrotik has already removed the .exe from their down load page and I am surprised it has not been removed from rOS already. And it hasn’t ever been proper to test to/from the device(s) you want to test.You are maxing out the CPU as it is not strong enough to generate the traffic and also pass it. And that bandwidth test only runs on a single core on multi-core CPU’s. Use iperf between 2 pc’s instead.
Bit of a bold claim.
A) he 816 drops on that link. Unless he's running 816 btest, this holds no weight
B) no where in his image does it show CPU running maxed out.
