ninja365
Signal Strength LED Issue - New SXT LTE Unit.
Tue Jun 26, 2018 11:07 pm
Hi all
I have just taken delivery of the new SXT unit with multi band support, upgraded to the latest os 6.42.4 but can't get the LED's to function properly. I have set them up as modem signal using the lte1 interface and set the threshold at LED 1 to -113 and then evenly through the other LED's to number 5 which is set at -51.
The unit is currently connected on channel 20 at -118dB and has all 5 LED's light up. Reset the configuration and reprogrammed the LED options but still the same. Need this to work out in the field as have to deploy several units in the next few days and its not always possible to be able to use a tablet/laptop to look at the signal strength on the interface.
Joe.
piterw
Re: Signal Strength LED Issue - New SXT LTE Unit.
Sun Oct 07, 2018 1:42 pm
same problem
ninja365
Re: Signal Strength LED Issue - New SXT LTE Unit.  [SOLVED]
Mon Oct 08, 2018 6:03 pm
I got this resolved from Mikrotik support by adding the following:
> Please, replace your /system leds config to this line: "/system leds add interface=lte1 leds=led1,led2,led3,led4,led5 modem-signal-treshold=-91 type=modem-signal"
Hope this helps
Joe.
Petri
Tue Oct 09, 2018 9:06 am
I asked this very same question two months ago with no reply from MikroTik: viewtopic.php?f=7&t=136598&p=680458#p680458
ninja365
Tue Oct 09, 2018 8:18 pm
Petri,
In addition to posting here, I also raised a support ticket directly with Mikrotik and received an answer inside 24 hours.
Joe.
Users browsing this forum: No registered users and 73 guests
