dc2
wAPR-2nD and Quectel EP06E Cat6 LTE modem
Tue Jul 03, 2018 12:18 am
I connected my wAPR-2nD with Quectel EP06-E Cat 6 mPCIe LTE modem (taped pins 23, 25, 31, 33 to get the board to recognize the modem) and it works with PPP.
Then I go: /port firmware set ignore-directip-modem=no
and: /system serial-terminal usb1 channel=2
(usb1 is my port from: /port print
and data channel for modem is 3, info channel is 2
from PPP status and having checked mikrotik queltec modem wiki page)
to send the following command to the modem:
AT+QCFG="usbnet",1
and I reboot to get LTE interface.
I get about 10-15Mbps download where my Cat6 phone gets 40Mbps...
Any ideas???
qbic
Re: wAPR-2nD and Quectel EP06E Cat6 LTE modem
Wed Jul 04, 2018 9:04 pm
What is CPU usage during PPP benchmark?
dc2
Mon Jul 09, 2018 9:15 pm
about 30%
SiB
Mon Sep 09, 2019 2:15 am
It's normal.
Phone can connect to other LTE Band then your EP06 and that's all.
You should check every Band by Band at EP06 and this way you can do proper connection.
BTW. You know that even connection will be Cat.6 with CA then your wAPR have got 100Mb port !. Be aware of that.
Check good howto at viewtopic.php?f=3&t=150368&p=742420&hilit=ep06#p740715 , next post have got info about change Band by AT command.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
Users browsing this forum: No registered users and 25 guests
