Madumi
highest power dual band AP?
Wed Jul 25, 2018 4:16 am
Hi guys,
I have a situation where one building would be best supplied by a higher power access point. Am I correct in thinking that the hAP ac currently is the highest power dual-band access point that Mikrotik produces?
I'd love to go with something like the metal with omni antenna, but I would prefer dual-band & pairing a metal 2 with a metal 5 seems a little awkward.
chechito
Re: highest power dual band AP?  [SOLVED]
Wed Jul 25, 2018 7:08 am
you can assemble this combo:
routerboard rbm33g
https://mikrotik.com/product/rbm33g
2ghz radio R11e-2HPnD
https://mikrotik.com/product/R11e-2HPnD
5ghz radio R11e-5HacD
https://mikrotik.com/product/R11e-5HacD
enclosure and antennas you can choose from the web there are many options
the advantage over hap ac2 will be the antennas
Madumi
Wed Jul 25, 2018 4:46 pm
much appreciated chechito,
Out of interest, do custom assembled routerboards play well together? i.e. are there many glitches (apart from rightly seating parts together) that one has to navigate (no offense meant... I'm used to building windows computers :-) ).
chechito
Wed Jul 25, 2018 7:01 pm
you are right more work and more expensive
but
for specific needs, specific solutions
it depends of the project we must see if it deserves this effort or not
Madumi
Wed Jul 25, 2018 7:25 pm
OK, sounds good... Can I assume the drivers for the mini pcie modules are included in routeros?
thanks!
bmatic
Mon Jul 30, 2018 10:46 am
I have a few of these, they work great:
https://mikrotik.com/product/RBMetalG-52SHPacn
Thor187
Thu Oct 04, 2018 11:04 pm
What settings do you have on them, power wise?
I have them, but the wifi ability (range) seems very bad.
Users browsing this forum: andresq and 33 guests
