SLAiDER
New MT and lots of new Problems
Sun Feb 11, 2007 12:28 pm
Hello
I started me new MT becouse me last mt (2.8) is too slow and sometimes get creazy :) So i think its time to change for new version 2.9 and new hardware P4 1.8 and new wifi cards:
Wlan1: Ubiquiti SuperRange 2 (SR2)
Wlan2: Senao NMP-8602-PLUS-400
But when i started this new MT i get lots of problem (I have last version 2.9.39) this is me problem:
1. Strangely "Signal Strenght (dBm)" < look the screen shot
2. Problem with negotiatiate good link speed like 5.5Mbps (On old Mt have no problem with negotiate 11Mbps here is problem with 5.5)
3. And old problem with "Data extensive loss" in log and other like this:
12:27:12 wireless,info 00:00:00:00:00:00@wlan1: disconnected, got disassoc: sending station leaving (8)
12:27:17 wireless,info wlan1: data from unknown device 00:00:00:00:00:00, sent deauth
13:38:22 wireless,info 00:00:00:00:00:00@wlan2: disconnected, extensive data loss
13:38:34 wireless,info wlan2: data from unknown device 00:00:00:00:00:00, sent deauth
Screen shot:
Tx for help !
ivaring
Sun Feb 11, 2007 1:59 pm
Hi, I'm having some of that problem.
I'm using MTK APs with Edimax Clients and I get a lot of disconnection messages.
I'll post results then.
Thanks.
SLAiDER
Sun Feb 11, 2007 2:51 pm
Clients have difrents cards:
- D-link
- Realtek
- Ralink
- Plant
APS:
- D-Link DWL-900AP+
- MiniTar Realtek RTL8186
npero
Sun Feb 11, 2007 3:06 pm
Try to change antena a or antena b in wireless config. Maybe you select wrong antena on wireless card.
SLAiDER
Sun Feb 11, 2007 3:14 pm
I have select correct antene. I make reboot and singal strenght goo now correct hmmm this is relly streangly. But whot now still is problem with good speed negotiation and with errors in logs. Meaby change MT version for older ? whot is recomendation MT version ?. Or meaby other ? meaby i need somtching change any options ?.
Diganet
Sun Feb 11, 2007 6:27 pm
Which channels are you using? TX power? How close are antennas to eachothers?
/Henrik
SLAiDER
Sun Feb 11, 2007 6:43 pm
wlan1: frequency=2457
wlan2: frequency=2422
This is same chanel whot i have on old MT 2.8 and they anennas stay on mast wlan1 antenn is higher on mast and wlan2 is under wlan1 antenn about 1m. TXPOWER is default
tgrand
Long time Member
Long time Member
Mon Feb 12, 2007 4:54 am
Replace the senao radio with an R52.
The router board with the senao is flaky in many different ways.
SLAiDER
Mon Feb 12, 2007 11:17 am
I dont use router board this is normal pc with p4 processor.
uldis
Mon Feb 12, 2007 11:22 am
SLAiDER, please make the support output file when you see these low singnals and send it to support@mikrotik.com
SLAiDER
Mon Feb 12, 2007 11:33 am
I send in (Staurday) but me big problem is problem with negotiation good speed like 5.5Mbps and problem with extensive data loss disconnected and other error disconnected in log. I think here is meany people who use MT and meaby any help me ?. So i write here too.
Log:
13:28:52 wireless,info wlan1: data from unknown device 00:00:00:00:00:00, sent deauth
13:28:55 wireless,info 00:00:00:00:00:00@wlan1: connected
13:28:56 wireless,info wlan1: data from unknown device 00:00:00:00:00:00, sent deauth
13:30:15 wireless,info 00:00:00:00:00:00: connected
13:31:00 wireless,info 00:00:00:00:00:00@wlan1: disconnected, got deauth: class 3 frame received (7)
13:31:04 wireless,info 00:00:00:00:00:00@wlan1: connected
13:31:27 wireless,info 00:00:00:00:00:00@wlan1: disconnected, extensive data loss
13:31:27 wireless,info wlan1: data from unknown device 00:00:00:00:00:00, sent deauth
13:31:58 wireless,info 00:00:00:00:00:00@wlan1: connected
13:32:39 wireless,info 00:00:00:00:00:00@wlan1: disconnected, got deauth: class 3 frame received (7)
13:32:54 wireless,info 00:00:00:00:00:00@wlan1: connected
13:32:54 wireless,info 00:00:00:00:00:00@wlan1: disconnected, got deauth: class 3 frame received (7)
13:33:26 wireless,info 00:00:00:00:00:00@wlan2: disconnected, extensive data loss
willywonka
Mon Feb 12, 2007 4:01 pm
Log:
hy,
in your first screen shot , you can note that your signal to noise is 61 dB, ... I think that this is too high.
Try to search a channel with noise floor around -88/-90 on the wlan2, maybe this can solve your disconnections.
SLAiDER
Mon Feb 12, 2007 4:54 pm
When i started search better noise floor on wlan2 i get -62 and on wlan1 i get -98 i search them on same chanel 2422 on wlan2 and wlan1 i have the best on wlan2 i got -62 and on wlan1 i got -81 but now on all channel i have about -95 too -100 no better and i back to old chan on wlan2 where i last see -62 now i have -95 ;/ meaby i have somthing wrong i configure interface ? here is print:
0 R name="wlan1" mtu=1500 mac-address=00:00:00:00:00:00 arp=enabled disable-running-check=no
interface-type=Atheros AR5213 radio-name="BALTYK" mode=ap-bridge ssid="FXNET" area="" frequency-mode=manual-txpower
country=no_country_set antenna-gain=10 frequency=2457 band=2.4ghz-b scan-list=default rate-set=configured
supported-rates-b=2Mbps,5.5Mbps supported-rates-a/g=6Mbps,9Mbps basic-rates-b=2Mbps,5.5Mbps
basic-rates-a/g=6Mbps,9Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
noise-floor-threshold=default periodic-calibration=disabled periodic-calibration-interval=60 burst-time=disabled
dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=pre-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=15s on-fail-retry-time=100ms preamble-mode=long
compression=no allow-sharedkey=no
1 R name="wlan2" mtu=1500 mac-address=00:00:00:00:00:00 arp=enabled disable-running-check=no
interface-type=Atheros AR5413 radio-name="BALTYK2" mode=ap-bridge ssid="FXNET2" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=10 frequency=2422 band=2.4ghz-b scan-list=default
rate-set=configured supported-rates-b=2Mbps,5.5Mbps supported-rates-a/g=6Mbps basic-rates-b=2Mbps,5.5Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=manual-table
dfs-mode=none antenna-mode=ant-b wds-mode=disabled wds-default-bridge=none wds-default-cost=100
Users browsing this forum: Bing [Bot], mbovenka and 36 guests
