The device is on relatively wifi clear zone (both 2 and 5 Ghz frequencies are mostly clear of other networks). I set both radios to separate bridge, assigned an IP on it, and assigned DHCP server to it, too. Another bridge and DHCP server is for LAN ports. Networks are different (that is, 192.168.5.0/24 on LAN bridge, and 192.168.6.0/24 on wifi bridge). There is a mascarade NAT rule for address list which includes both 5 and 6 subnets.
The problem is, LAN clients can use Internet on full speed, while wifi clients clain they see 200-300 bits/sec speed. Hard to tell if this is for 2 Ghz only (due to they don;t have 5 Ghz clients at all), but this appears to be wifi hardware related issue, due to very basic setup made so far.
Here is the radio setup:
Code: Select all
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=ThisOne supplicant-identity="" wpa2-pre-shared-key=keykeykey
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-onlyn comment="2 Ghz" country=russia3 disabled=no distance=indoors frequency=2442 frequency-mode=regulatory-domain hw-protection-mode=rts-cts mode=ap-bridge multicast-buffering=disabled multicast-helper=disabled name=wlan_2Ghz security-profile=ThisOne ssid=SSID_2 wireless-protocol=802.11
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee comment="5 Ghz" country=russia3 disabled=no distance=indoors frequency=5260 frequency-mode=regulatory-domain hw-protection-mode=rts-cts mode=ap-bridge name=wlan_5Ghz security-profile=ThisOne ssid=SSID_5 wireless-protocol=802.11
/interface wireless manual-tx-power-table
set wlan_2Ghz comment="2 Ghz"
set wlan_5Ghz comment="5 Ghz"
/interface wireless nstreme
P.S. By the way, what is the nstreme interface I can see here?
