dboreham
MT alternatives for 17Km link?
Thu Aug 30, 2018 5:34 pm
I have a 17Km p2p link using MAnt30 solid dishes and NetMetal5 units. The link has never performed satisfactorily in the 2 years it has been running : using nstreme we see decent throughput but the link disconnects completely and reconnects, every few hours (even though it works perfectly well in between). Using NV2 the link is rock solid but throughput is 1/2 what we achieve with nstreme (and below requirements which are at least 100Mbits 1/2 duplex). 802.11 seems to work but is slower than NV2.
We've been running MT gear for 10+ years and I'm very familiar with its configuration, RF engineering in general. It has come to the point where I am looking for suggestions for alternative products to try on this link. Ideally I would like to retain the existing dishes since they are aligned and in place, so I'm looking for radios without integrated antennas, and obviously 1/2 duplex. One end of the link is solar powered so I can't use gear that has very high power requirements.
Thanks.
mistry7
Re: MT alternatives for 17Km link?
Thu Aug 30, 2018 5:44 pm
Options from my side:
Mimosa C5C need about 10W (48V)
or if you want to go to MAX bandwidth on this Link
UBNT Airfiber 5X HD need about 8W ( 24v)
Lakis
Forum Veteran
Forum Veteran
Thu Aug 30, 2018 11:12 pm
Airfiber 5 need 8w 24v?????
AF5 need 42~58v up to 40w
dboreham
Fri Aug 31, 2018 1:23 am
According to spec AF5XHD runs on 24-50V @ 12W max (6W min, so 8W typ would make sense).
Much less than AF5 and more solar friendly. I have a 24V nominal power power system at the site.
dboreham
Fri Aug 31, 2018 1:24 am
Thanks. AF5XHD looks very interesting. Not sure if I have the days left before the snow arrives to deploy, so probably a project for the spring..
mistry7
Fri Aug 31, 2018 6:35 am
AF5X HD not AF5
He is searching an connector Based Radio.....
human1982
Fri Aug 31, 2018 9:56 am
Thanks.
162/162 98% ccq gives stable 100/10 in NV2 tdma 2ms avg ping 5ms soft 6.43 rc34
mistry7
Fri Aug 31, 2018 10:25 am
AF5X
-15km
-36dBm allowed (Europe)
-30dBi Dishes
- 90% clear LOS
- Solar Powered
Resulted in 280 MBit Down / 60 MBit UP (75/25)
We use a not 100% clear 50 MHz Channel
With Uograde to AF5X HD we hope to see more than 400MBit
Lakis
Forum Veteran
Forum Veteran
Fri Aug 31, 2018 12:13 pm
AF5X HD not AF5
Oh that one airFiberX :)
dboreham
Fri Aug 31, 2018 5:31 pm
Another question : do you know if the pigtails have the same connector (between NetMetal and AF 5X?). Both are described as "RP-SMA" so I would think the answer is yes.
mistry7
Fri Aug 31, 2018 6:46 pm
Yes they fit no problem......
Users browsing this forum: No registered users and 18 guests
