Hi.
I Have Capsman Network.
client mode is station-bridge and cannot connect to CAP.in Log "does not allow station-bridge" message is displayed.
why ?
Is there any solution?
thanks alot.
thanks for reply.I'm not sure what you mean. What's in station mode? The remote router?
If so, the remote router it's meant to be an AP, and nothing else. Once configured as a capsman client, you can't configure the wifi radio unless it's from the capsman.
Regards
Sent from Tapatalk
Mode station-pseudobridge
From the wireless connection point of view, this mode is the same as standard station mode. It has limited support for L2 bridging by means of some services implemented in station:
MAC address translation for IPv4 packets - station maintains IPv4-to-MAC mapping table and replaces source MAC address with its own address when sending frame to AP (in order to be able to use 3 address frame format), and replaces destination MAC address with address from mapping table for frames received from AP. IPv4-to-MAC mappings are built also for VLAN encapsulated frames.
single MAC address translation for the rest of protocols - station learns source MAC address from first forwarded non-IPv4 frame and uses it as default for reverse translation - this MAC address is used to replace destination MAC address for frames received from AP if IPv4-to-MAC mapping can not be performed (e.g. - non-IPv4 frame or missing mapping).
This mode is limited to complete L2 bridging of data to single device connected to station (by means of single MAC address translation) and some support for IPv4 frame bridging - bridging of non-IP protocols to more than one device will not work. Also MAC address translation limits access to station device from AP side to IPv4 based access - the rest of protocols will be translated by single MAC address translation and will not be received by station itself.
This mode is available for all protocols except nv2 and should be avoided when possible. The usage of this mode can only be justified if AP does not support better mode for L2 bridging (e.g. when non-RouterOS AP is used) or if only one end-user device must be connected to network by means of station device.
how mikrotik say "clients should be configured in station-bridge mode" ? How is it possible ?When set to full multicast packets will be sent with unicast destination MAC address, resolving multicast problem on wireless link. This option should be enabled only on access point, clients should be configured in station-bridge mode. Available starting from v5.15.
disabled - disables the helper and sends multicast packets with multicast destination MAC addresses
full - all multicast packet mac address are changed to unicast mac addresses prior sending them out
default - default choice that currently is set to disabled. Value can be changed in future releases.
