oopsxp
How can I enable a device to connect wifi for only 2 hours per day without setting hotspot
Sun Sep 23, 2018 9:47 am
as subject. Thanks
Static IP of the device has been set (i.e. 192.168.88.20)
UpRunTech
Re: How can I enable a device to connect wifi for only 2 hours per day without setting hotspot
Tue Sep 25, 2018 10:11 pm
as subject. Thanks
Use Kid Control. It's not very well named as it actually drives them crazy and out of control.
https://wiki.mikrotik.com/wiki/Manual:Kid-control
Redmor
Wed Sep 26, 2018 4:19 pm
You can use Time under access list rule, never tried it, but should work.
xvo
Forum Veteran
Forum Veteran
Wed Sep 26, 2018 6:31 pm
That won't work.
And the kid control feature as well.
They both can only restrict the hour ranges when the client can stay connect, not the total connected time per day.
UpRunTech
Wed Sep 26, 2018 11:43 pm
That won't work.
True, there was some ambiguity to the question.
Hotspot might be easiest. If you want to only have selected devices use the hotspot you can add their MAC in the access list and force them onto a VLAN+bridge that runs the hotspot without needing to use a new SSID. Otherwise, just make a new SSID with the hotspot on it. Even then I don't know if on hotspot you can lock a device out when it's used up it's allocation for a 24H period. It might need some extra scripting to support this.
allstarcomps
Thu Sep 27, 2018 8:56 am
Set DHCP lease time to 24hrs
DHCP lease script add the host IP to a firewall list named "allowedLan" with a 2hr time out.
Firewall filter forward chain accept traffic from the src address list=allowedLan
Firewall filter forward chain drop traffic from the screen address list!=allowedLan
UpRunTech
Thu Sep 27, 2018 11:52 pm
This is only good if the requirement is to start the clock from the moment the device is turned on. I think the OP needs to define the problem more succinctly.
Is it:
* 2 hours from device powerup?
* 2 hours of web browsing?
* 2 hours contiguous use?
* 2 hours accumulated over 24h rolling window?
* 2 hour window before kids bedtime?
Given most computing devices are on all the time and sleep and wake and do a DHCP request often the DHCP script might not be the solution.
Jotne
Sun Sep 30, 2018 10:23 am
The problem I do have with this, is that the kids uses internet on the cell phone if I turn of the Wifi.
Either their own phone or friend phone.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
Users browsing this forum: No registered users and 22 guests
