CREATIVELINK
Hidden SSID
Fri Feb 16, 2007 4:32 pm
please i need to know how can i make a hidden SSID i just check the hidden ssid box on the wireless interface but when i do scan i SEE ' it
any help
janisk
Fri Feb 16, 2007 5:24 pm
/in wi set <interface name here> hide-ssid=yes
CREATIVELINK
Sat Feb 17, 2007 9:19 am
i still can see it in the scan
balimore
Forum Veteran
Forum Veteran
Sat Feb 17, 2007 3:59 pm
i think mikrotik much cleber will see hide and unhide ssid :wink:
but other wireless can't see mikrotik when hide-ssid=yes
Hasbullah.com
spire2z
Long time Member
Long time Member
Sat Feb 17, 2007 8:25 pm
Probably because the ssid is configured into your computer. Try removing it from your list of configured ssid and try scanning again :)
ivaring
Mon Feb 19, 2007 10:18 am
Right!.
If you configured in past that SSID, your PC will be always seeing that SSID.
I had that problem solved.
Regards.
CREATIVELINK
Mon Feb 19, 2007 10:24 am
Right!.
Regards.
NO . im using MT to scan in dlink 2100ap i see the mac of the wireless card but hidden ssid , in MT i see the SSID normaly
janisk
Mon Feb 19, 2007 10:40 am
i just cannot get it, where is the problem?
you are scanning from MT your wireless and you see your Dlinks SSID and MAC address, but ssid should be hidden?
is your MT set to same ssid?
CREATIVELINK
Mon Feb 19, 2007 10:45 am
sir ,
i have this scenario ,
MT1 (wirreless interface with hidden SSID)
Dlink (as Access Point Client when i scan from her i see only the mac of MT1 )
MT2 (as Access Point Clinet when i scan i see the SSID of MT1 Normaly )
i need to hide MT1 SSID for all Scan from any device
Please Advice
janisk
Mon Feb 19, 2007 10:50 am
MT has this feature that it can get any ssid no matter it is hidden or no, at least using snooper you can get ssid if there is any traffic going on.
balimore
Forum Veteran
Forum Veteran
Mon Feb 19, 2007 10:58 am
sir ,
Please Advice
I think you are true,
cause it option is hide-ssid=yes, and not for mac-address :wink:
and for me that methode is not problem.
regards
Hasbullah.com
normis
Mon Feb 19, 2007 2:47 pm
in simple words - other devices will not see your SSID if you hide it. other MT will be able to see it.
CREATIVELINK
Fri Feb 23, 2007 2:05 pm
thanks for your help all
hckr00t
hide ssid
Tue Feb 27, 2007 4:59 pm
when you hide SSID people normaly wont see it ...
some software can see only the mac address (ex: netstumbler) can see the mac address of the AP that is transmiting the signal ..
so users can't actually connect to the mac address only ...
and as about d-link software on winxp .. it can also see the mac address of the access point .. but still can't connect .. i've tried it many times.
cheerz
uldis
Re: hide ssid
Tue Feb 27, 2007 5:38 pm
cheerz
In windows usually you should activate the profile which has that specific ssid specified and it will connect to it. But it also depends on your wireless clients aplication.
Users browsing this forum: No registered users and 20 guests
