MUM Europe 2020
WirelessRudy
Hotspot authentication several users behind 1 CPE antenna.
Fri Mar 02, 2007 1:35 am
I have set up a Hotspot in a wireless environment. To save on cost for CPE´s some CPE´s (Not MT) have two or more clients (users, or for instance several PC´s with a hub or switch) behind that CPE antenna.
The authentication takes now place on the first node that logs in because the hotspot binds the users dynamicaly generated ip (hotspot assignment) on the mac adress of the CPE. After this all nodes can just browse (if multple allowed sessions for the user)
The Hotspot ´host´ list shows the mac of the CPE with the ip adress that is assigned by the first node that logs in? I want every node that logs in to be presented with a login screen, so every separate user has to log in separately. Who can help me out here?
The CPE runs in Client Bridge mode with fixed ip´s.
sergejs
Fri Mar 02, 2007 8:11 am
You need to ensure, that CPE is operating in 'true' bridge mode, otherwise they will be presented on host list with the same MAC-address (CPE) but with different IP addresses.
WirelessRudy
Fri Mar 02, 2007 10:47 pm
With ´true´ bridge mode you mean a sort of ´transparant´ behaviour? Then Client PC´s just are shown by the host, not the CPE´s mac?
The client CPE´s are all SmartBridges, I can´t actually change their behaviour I think.
Webmaster: According the log my origianal message was post on 12:35 am Fri Mar 02, while Sergejs replied on it at 7:11 am the same day!
How can he reply almost 5,5 hours BEFORE my original message?
You need to check time settings of this forum.
tneumann
Fri Mar 02, 2007 11:31 pm
Well, then you'll have no way to fix this. Get another brand of CPE, one that does support fully transparent bridging (which - in the context of 802.11 - means WDS) or ask SmartBridges if they can tell you how to solve this with their equipment.
--Tom
WirelessRudy
Sat Mar 03, 2007 1:44 am
OK, so that´s it for SmartBridges then...
But how should my topologie look like when using MT base CPE´s?
Set them up as ´bridge´ (bridge all interfaces) and have a hub/switch behind them to connect to different users of the HotSpot?
acim
Sat Mar 03, 2007 1:45 am
For example, D-Link 900 behaves just as you want. You can see it's MAC address, but all user MAC's as well.
WirelessRudy
Sat Mar 03, 2007 2:15 am
D-Link 900 is ip cam. What do you mean?
wildbill442
Sat Mar 03, 2007 6:22 am
I think he meant the DWL-900AP+
tneumann
Sat Mar 03, 2007 11:32 am
Yes, and you need to use station-wds on the CPE to get transparent bridging.
--Tom
Users browsing this forum: Google [Bot], yannick and 25 guests
