NoBrainer
Redirect traffic from specific device to another local ip
Thu Jan 03, 2019 11:17 am
Hello MikroTik community!
I want to redirect all the tcp traffic from a Nintendo Switch to my RaspberryPi. Would be nice if this could somehow be combined with the "Kid control" feature to do this from e.g. 22:00(10pm) - 7:00(7am) on the next day.
I've got the following setup at home:
MikroTik RBLHG5nD - 192.168.1.1 (static) This is the gateway which is located at my provider's local branch (Internet is provided by directional radio)
MikroTik hAP lite - 192.168.1.115 (not static)
Nintendo Switch - 192.168.1.116 (not static yet)
Raspberry Pi - 192.168.1.20 (static)
Kind regards
baragoon
Re: Redirect traffic from specific device to another local ip
Thu Jan 03, 2019 11:22 am
try something like this
/ip firewall nat add action=netmap chain=dstnat protocol=tcp src-address=nintendo_ip to-addresses=raspberry_ip
NoBrainer
Thu Jan 03, 2019 11:28 am
Should I do that on my Router/Bridge or do I have to ask the provider to do this on their router?
Cha0s
Thu Jan 03, 2019 11:39 am
Maybe something link this (to accommodate for the time requirements).
/ip firewall nat add chain=dstnat src-address=192.168.1.116 time=22h-7h,sun,mon,tue,wed,thu,fri,sat action=dst-nat to-addresses=192.168.1.20
Also, this thread needs to be moved to some other category. It has nothing to do with wireless networking.
NoBrainer
Thu Jan 03, 2019 11:40 am
It's not working when doing on my router so I guess I have to ask my Provider??
Not working means that I can access any website although this NAT Rule is enabled.
Edit: This post is related on post #2
NoBrainer
Thu Jan 03, 2019 11:45 am
And @Chaos your solution is also not working. As I said in the other posts: Can I do it on my Router/Bridge at home or do I have to ask my provider to do this at their router which is the gateway of our devices?
baragoon
Thu Jan 03, 2019 12:15 pm
you should do it here - MikroTik RBLHG5nD - 192.168.1.1
Petri
Fri Jan 04, 2019 10:06 am
You need to do it on a router where the Nintendo is directing the traffic. Currently the provider router is the default gateway so it should happen there. However, I doubt the provider will do a special config for you. It would be a maintenance headache for them in the future. Your best bet would be to connect the Nintendo to one of the hAP Lite ports, take that port off the bridge and do the firewalling there. Or you could buy another small MT device and place it between the ISP router and your network.
Why are you asking this on the wireless forum? This is a pure routing problem.
Users browsing this forum: jaclaz and 42 guests
