Shurikkk
High ping to router HAP AC2
Tue Jan 08, 2019 9:40 pm
Hello, i have a problem with my new Hap AC2.
When i play some online games or watch demo in Discord, i get ping spikes.
The problem on 1 hop(192.168.88.1), can someone help me because im new to RouterOS?
My config:
# jan/08/2019 21:26:36 by RouterOS 6.42.10
# software id = FWTF-Q0NB
# model = RBD52G-5HacD2HnD
# serial number = A97409CBA4BE
add fast-forward=no name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=int password=6741001 use-peer-dns=yes user=2559400
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40mhz-Ce mode=ap-bridge ssid=MikroTik wmm-support=enabled
/interface wireless nstreme
set wlan2 enable-polling=no
add name=lan5
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 supplicant-identity="" wpa2-pre-shared-key=hidden
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-onlyn country=russia disabled=no distance=indoors mode=ap-bridge security-profile=\
    profile1 ssid="hidden" wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set wlan1 enable-polling=no
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.50
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.50
add address-pool=dhcp_pool1 disabled=no interface=bridge1 lease-time=8h name=dhcp1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
set discover-interface-list=lan5
add interface=ether5 list=lan5
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=192.168.88.0/24 dns-server=83.219.128.10,83.219.128.14 gateway=192.168.88.1
add action=drop chain=input comment="Drop Invalid connections" connection-state=invalid disabled=yes
add action=accept chain=input comment="Allow Established connections" connection-state=established disabled=yes
add action=accept chain=input comment="Allow ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="LAN to INT" disabled=yes in-interface=!int src-address=192.168.88.0/24
add action=drop chain=input comment="Drop everything else" disabled=yes
add action=masquerade chain=srcnat out-interface=int src-address=192.168.88.0/24
add action=netmap chain=dstnat dst-port=9987 in-interface=int protocol=udp to-addresses=192.168.88.47 to-ports=9987
add action=netmap chain=dstnat dst-port=30033 in-interface=int protocol=tcp to-addresses=192.168.88.47 to-ports=30033
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=int type=external
/system clock
set time-zone-name=Europe/Kaliningrad
/system ntp client
set enabled=yes primary-ntp=88.147.254.232
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=lan5
/tool mac-server mac-winbox
R1CH
Forum Veteran
Forum Veteran
Re: High ping to router HAP AC2
Wed Jan 09, 2019 12:41 pm
Make sure you're configuring / connecting to wlan2 (5 GHz), 2.4 GHz is too noisy for reliable connections.
mkx
Wed Jan 09, 2019 1:29 pm
And upgrade your hAP ac2 to latest stable (6.43.8 at this time) ... wireless might perform better.
BR,
Metod
Shurikkk
Wed Jan 09, 2019 9:02 pm
Thanks for reply, i updated fireware to latest stable, and i can't use 5ghz and this problem on 5ghz too.
P.S. I have old wr1043nd with 2.4ghz and all works fine!
deanMKD1
Wed Jan 09, 2019 11:11 pm
Upgrade to latest "long-term" package. Its bugfix version.
Shurikkk
Thu Jan 10, 2019 4:34 pm
I tried all versions of RouterOS (stable version, bug fixes, testing), but it did not solve my problem!
Even when I disconnect the Internet from the router and turn on the router at a distance of 10 cm from the PC, the problem with ping to 192.168.88.1 remains the same!
Maybe hardware problem?
Or its can be a software problem?
mkx
Thu Jan 10, 2019 6:08 pm
For the record: what kind of ping times are we talking about?
BR,
Metod
Shurikkk
Thu Jan 10, 2019 6:36 pm
Ping from PC to Router, thats happend on every PC(
Pea
Thu Jan 10, 2019 7:40 pm
There should be <1ms for ping even over wifi. What are you getting?
Shurikkk
Thu Jan 10, 2019 7:48 pm
from 1-3ms to 200ms or even 2000ms, just random ping spikes!
Shurikkk
Thu Jan 10, 2019 10:47 pm
Pinging 192.168.88.1 with 32 bytes of data:
Reply from 192.168.88.1: bytes=32 time=1ms TTL=64
Reply from 192.168.88.1: bytes=32 time=748ms TTL=64
Reply from 192.168.88.1: bytes=32 time=18ms TTL=64
Reply from 192.168.88.1: bytes=32 time=3ms TTL=64
Reply from 192.168.88.1: bytes=32 time=2ms TTL=64
Reply from 192.168.88.1: bytes=32 time=72ms TTL=64
Reply from 192.168.88.1: bytes=32 time=105ms TTL=64
Reply from 192.168.88.1: bytes=32 time=387ms TTL=64
Reply from 192.168.88.1: bytes=32 time=8ms TTL=64
Reply from 192.168.88.1: bytes=32 time=55ms TTL=64
Reply from 192.168.88.1: bytes=32 time=86ms TTL=64
Reply from 192.168.88.1: bytes=32 time=11ms TTL=64
Reply from 192.168.88.1: bytes=32 time=33ms TTL=64
Reply from 192.168.88.1: bytes=32 time=6ms TTL=64
Reply from 192.168.88.1: bytes=32 time=31ms TTL=64
Reply from 192.168.88.1: bytes=32 time=14ms TTL=64
Reply from 192.168.88.1: bytes=32 time=19ms TTL=64
Reply from 192.168.88.1: bytes=32 time=16ms TTL=64
Reply from 192.168.88.1: bytes=32 time=13ms TTL=64
Reply from 192.168.88.1: bytes=32 time=39ms TTL=64
Does someone have a similar problem?
Shurikkk
Fri Jan 11, 2019 10:16 am
Any help?
sebastia
Fri Jan 11, 2019 12:03 pm
What interface is the client? I've seen that too with some intel cards and some driver versions, where it would show spikes in response.
erlinden
Fri Jan 11, 2019 12:19 pm
Are you using fixed channels?
Why do you have two (overlapping) DHCP pools?
Why UPnP?
Shurikkk
Fri Jan 11, 2019 12:37 pm
I have old atheros ar9565.
Shurikkk
Fri Jan 11, 2019 12:40 pm
Why UPnP?
I deleted second pool yestarday.
UPnP because i use some apps with dynamic ports.
Problem persists without UPnP too.
Shurikkk
Fri Jan 11, 2019 5:31 pm
I have revision with 128mb memory btw!
Shurikkk
Fri Jan 11, 2019 6:00 pm
And when i launch Speed Test, my ping from PC to Router became 300-2000 or packet loss!
Shurikkk
Fri Jan 11, 2019 6:38 pm
And I have bufferbloat and only with mikrotik.
On my old WR1043ND-max 30ms bufferbloat!
When I connect the cable to PC-max 30ms buffebloat!
And on my Mikrotik hap ac2 I have 130ms on download and more than 250ms to upload!And this is strange!
P.S. I have bufferbloat even with simple queue.
Shurikkk
Fri Jan 11, 2019 9:24 pm
I think i will replace it to other one hap ac2 because i think its problem with hardware.
Shurikkk
Tue Jan 29, 2019 6:43 pm
I bought new Hap ac^2 and NOTHING has changed!!!
I cant understand why my old bad router don't have this problem?
And this router has it?
Shurikkk
Wed Jan 30, 2019 6:30 pm
Any help?
Pea
Thu Jan 31, 2019 8:42 pm
Did you try to reset to factory default and test? What was the result?
You are connected via 2.4GHz or 5GHz?
Did you try to change channel?
deanMKD1
Thu Jan 31, 2019 11:02 pm
This is ping to my Local PC.
This is Speedtest made from Unifi that is cable connected to my hap ac2.
and this is speedtest made when im connected to my hap ac2 wirelessly.
Not sure why too high ping.. Speed seems fine to me.
Shurikkk
Sun Feb 03, 2019 11:14 pm
I plugged in the Hap ac2 elsewhere with only 2 wifi routers and tried to run the game and I had 300ms ping.
Then I connect to another Microtik and got a good ping 50-60ms!
I really can't figure out what the problem is! And how to fix it. In the beginning I thought it was a hardware problem but then I buy another hap ac2 but the problem persists and now I think it is a software problem(but there is a lot of other people without that problem) or I am so lucky that I got 2 routers with a hardware problem;).
It's really weird when a router from 2010 works better than a new one!
I even wrote to Mikrotik support and waiting for an answer!
Help?
P.S. I have tried a lot of things:
1. Change channels and channel width
2. All firmwares from long-term to testing
3. Another PC
4. Another place for router and another ISP
And a lots of other things!
mkx
Mon Feb 04, 2019 12:37 pm
I think that you could rule out HW failure by trying with plain factory default config, possibly preceeded by netinstall with default settings applied ... don't change a thing (even use default SSID). Start with pinging hAP ac2 itself ... if pings vary wildly, then complain to support@mikrotik.com.
If, however, pingshave nice uniform low RTT time, proceed with pinging your LAN gateway. If pings keeps to be low, then HW is fine and you need to carefully adapt configuration. Test for changes in ping times after every configuration change step and you might find out which configuration makes your hAP ac2 behave strangely.
BR,
Metod
Shurikkk
Mon Feb 04, 2019 3:13 pm
Thank you for your reply.
I'll do netinstall and cheak ping.
But i have a question can i connect PPPOE or i need fully default config??
mkx
Mon Feb 04, 2019 4:09 pm
I don't think that power supply choice (barrel connector vs. PoE in) makes any difference, but just to rule out the possibility that there's some problem with PoE I'd go with really base line setup (including powering).
BR,
Metod
Shurikkk
Mon Feb 04, 2019 4:37 pm
I think you misunderstood me! I meant my Internet!
Shurikkk
Mon Feb 04, 2019 5:23 pm
I did install with netinstall with default conf.
and i still have ping spikes average ping 2-5ms with spikes to 70-200ms.
neutronlaser
Mon Feb 04, 2019 6:04 pm
Use a wire or Powerline
Shurikkk
Mon Feb 04, 2019 6:26 pm
I can't, and my old router works good in same place!
R1CH
Forum Veteran
Forum Veteran
Mon Feb 04, 2019 7:05 pm
This isn't too surprising, Mikrotik wifi is generally poor compared to the competition. Join me in waiting for RouterOS v7 when hopefully we aren't running on drivers and kernel from 2012.
Shurikkk
Mon Feb 04, 2019 7:55 pm
Perhaps, but I only have problems with hap ac2, I don’t have them on a borrowed microtik, and this is strange.
Users browsing this forum: No registered users and 36 guests
