GuntOn
SXTsq in PTP link don't use chosesn frequency
Fri Jan 11, 2019 8:38 pm
I have a point to point link with two SXTsq 5ac antennas in a little bit crowded environment so I decided to use less used frequency but both of antennas does not use chosen frequency. I can set them to use 5600 MHz eCee channel and settings stay that way but status information shows 5200 eCee channel. Same time I have a PTmP setup with OmniTIK 5ac as AP and few SXTsq 5ac antennas as clients and I can use any frequency I set. Looks like this is a specific problem with SXTsq 5ac in PTP mode. Anybody have similar problem? Maybe I should to report this problem to support?
mistry7
Re: SXTsq in PTP link don't use chosesn frequency
Fri Jan 11, 2019 9:42 pm
Did you use your country setting?
Did you know anything about DFS
GuntOn
Fri Jan 11, 2019 9:56 pm
Yes I am using my country (Latvia) settings but I don't think that is a problem because in almost same physical location PTmP working fine on 5600 eCee channel.
mfr476
Fri Jan 11, 2019 10:01 pm
Arm is unfixed and have a lot of problems
Users browsing this forum: muetzekoeln, networkfudge, neutronlaser and 11 guests
