MUM Europe 2020
magnusak
Unable to connect to 2.4Ghz
Thu Feb 14, 2019 5:27 pm
I have an office setup with a RB4011iGS+ doing generic office routing as well as CAPsMAN for two cAP ac to cover a fairly small office.
My problem is that I am unable to use 2.4 Ghz wifi. Everything works fine for 5 Ghz clients. For debugging purposes I have set up two SSIDs, one called "company.5g" and one called "company.2g". Any attempt to connect to "company.2g" fails, and "company.5g" works. I have tried from several clients. Currently I get nothing in the log, but I have seen "4-way handshake" errors. Both the mentioned networks use the same security config, though.
See relevant config below (edited for confidentiality):
# feb/14/2019 16:08:55 by RouterOS 6.43.12
# software id = 5XDT-UT6X
# model = RB4011iGS+
# serial number =
/caps-man channel
add band=5ghz-onlyac name=5g-channel-auto reselect-interval=12h \
    skip-dfs-channels=no
add band=2ghz-b/g/n name=2g-channel-auto reselect-interval=12h
add fast-forward=no name=bridge-clientvpn
add admin-mac=BX::::X8 auto-mac=no name=bridge-internal
add fast-forward=no name=bridge-wifi-internal
add fast-forward=no name=bridge-wifi-public
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] name=ether9-ap-conference
set [ find default-name=ether10 ] name=ether10-ap-entrance poe-out=off
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-wan name=\
    wan-xx-fiber user=xx@xx
/caps-man datapath
add bridge=bridge-internal client-to-client-forwarding=yes name=\
    internal-datapath
add bridge=bridge-wifi-public client-to-client-forwarding=no name=\
    public-datapath
/caps-man security
add authentication-types=wpa2-psk name=companyinternal-security
add authentication-types=wpa2-psk name=companypublic-security
add authentication-types=wpa2-eap eap-methods=passthrough \
    eap-radius-accounting=yes encryption=aes-ccm group-encryption=aes-ccm \
    name=companycorporate-security
/caps-man configuration
add channel=2g-channel-auto country=spain datapath=internal-datapath mode=ap \
    name=cap-internal-2g security=companyinternal-security ssid=company.local
add channel=5g-channel-auto country=spain datapath=internal-datapath \
    distance=indoors name=cap-internal-5g security=companyinternal-security \
    ssid=company.local
add datapath=public-datapath name=cap-public security=companypublic-security \
    ssid=company
add datapath=internal-datapath name=cap-corporate security=\
    companycorporate-security ssid=company.corporate
add datapath=public-datapath name=cap-public-2g security=\
    companypublic-security ssid=company.2g
add datapath=public-datapath name=cap-public-5g security=\
    companypublic-security ssid=company.5g
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcppool-wifi-internal ranges=10.209.29.140-10.209.29.240
add name=dhcppool-internal ranges=10.209.30.140-10.209.30.240
add name=dhcppool-vpn ranges=10.209.31.140-10.209.31.240
add name=dhcppool-wifi-public ranges=10.209.20.140-10.209.20.240
add address-pool=dhcppool-wifi-internal disabled=no interface=\
    bridge-wifi-internal lease-time=1d name=dhcp-wifi-internal
add address-pool=dhcppool-internal disabled=no interface=bridge-internal \
    lease-time=1d name=dhcp-internal
add address-pool=dhcppool-wifi-public disabled=no interface=\
    bridge-wifi-public lease-time=1d name=dhcp-wifi-public
/system logging action
add bsd-syslog=yes name=diskstation remote=10.209.30.14 target=remote
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    cap-internal-5g name-format=prefix name-prefix=cap-5g \
    slave-configurations=cap-public,cap-corporate,cap-public-5g
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
    cap-internal-2g name-format=prefix name-prefix=cap-2g \
    slave-configurations=cap-public,cap-corporate,cap-public-2g
add bridge=bridge-internal interface=ether10-ap-entrance
add bridge=bridge-internal interface=ether2
add bridge=bridge-internal interface=ether9-ap-conference
add comment=defconf disabled=yes interface=ether1-wan list=WAN
add interface=ether2 list=LAN
add interface=ether10-ap-entrance list=LAN
add interface=bridge-internal list=LAN
add interface=wan-xx-fiber list=WAN
add interface=bridge-clientvpn list=LAN
add interface=bridge-wifi-internal list=LAN
add interface=ether9-ap-conference list=LAN
add address=10.209.29.1/24 interface=bridge-wifi-internal network=10.209.29.0
add address=10.209.30.1/24 interface=bridge-internal network=10.209.30.0
add address=10.209.31.1/24 interface=bridge-clientvpn network=10.209.31.0
add address=10.209.20.1/24 interface=bridge-wifi-public network=10.209.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1-wan
/ip dhcp-server lease
add address=10.209.30.8 mac-address=BX::::X3 server=dhcp-internal
add address=10.209.30.5 mac-address=BX::::X4 server=dhcp-internal
add address=10.209.20.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.209.20.1
add address=10.209.29.0/24 dns-server=10.209.30.128,10.209.30.129,10.130.49.50 \
    gateway=10.209.29.1 netmask=24
add address=10.209.30.0/24 dns-server=10.209.30.128,10.209.30.129,10.130.49.50 \
    gateway=10.209.30.1 netmask=24
set servers=10.209.30.128,10.209.30.129,1.1.1.1
/ip dns static
add address=10.209.31.1 name=router.lan
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system logging
add action=diskstation topics=critical
add action=diskstation topics=error
add action=diskstation topics=info,!caps
add action=diskstation topics=warning
add topics=caps
add topics=wireless,debug
add topics=caps,debug
I have tried factory resetting both the cAPs. All devices are on latest stable firmware.
I am operating basically the same infrastructure in two other locations, and there it seems to work.
Update: It seems this is because I am using slave configurations. This works for 5 Ghz, not for 2.4 Ghz. No idea why.
Any ideas?
sirhcjw
Re: Unable to connect to 2.4Ghz
Wed Feb 27, 2019 10:17 pm
We have this exact same problem.
Bump anyone have any ideas?
magnusak
Fri Mar 08, 2019 11:37 am
I have just upgraded my routers and access points to v 6.44 and it did not help.
I still have this problem where I cannot use 2.4 Ghz. Any ideas? Should I contact support?
erlinden
Fri Mar 08, 2019 12:02 pm
I would start by selecting channels manually. For 2G radio use either 1, 6 or 11 and make sure bandwidth is set to 20MHz.
magnusak
Fri Mar 08, 2019 12:53 pm
I am getting closer to a solution. Auto vs manual frequency does not seem to matter, but when not using slave configurations I do manage to connect (I use master and slave configurations for different SSIDs). I will do some more experiments and see if I get to a conclusion.
magnusak
Fri Mar 08, 2019 2:14 pm
I have now done a lot of experiments and come to the conclusion that 2.4 Ghz wifi does not work on my setup when using slave configurations. I.e. neither the master nor the slave configuration works, if I have any slave configuration activated on the 2.4 Ghz radio. If anyone wants to suggest any config, please let me know.
nishi
Fri May 17, 2019 3:11 pm
I am having the same issue. 2.4GHz interface shows in: "not running and Slave" mode. Hence the AP for 2.4GHz doesn't show up in the scan in any of the devices.
Did this get resolved?
medi01
Thu Jan 02, 2020 9:33 am
Any solution to this problem?
Get exactly the same issue, 5Ghz works, 2.4Ghz "cannot connect".
CAP AC in Dual AP Home mode.
Users browsing this forum: No registered users and 23 guests
