neutronlaser
Directional antenna for Groove A 52 ac
Sat Feb 16, 2019 3:52 pm
Is there a suitable directional antenna for Groove A 52 ac?
neutronlaser
Re: Directional antenna for Groove A 52 ac
Thu Feb 28, 2019 10:49 pm
load of shite
vecernik87
Long time Member
Long time Member
Fri Mar 01, 2019 12:35 am
As long as the antenna support frequency, which you want to use, it is suitable. (you didn't say anything so I am not sure what suggestion would you expect)
After that, all you need to worry is :
- connector, but that can be easily sorted by a short cable, which you will most likely use anyway, in order to properly mount your groove vertically.
- the beam width, gain, polarization, mount type, size, weight, wind rating, power rating.. (and probably all other properties) but those depend on your application, not your device.
You don't need to worry about manufacturer. There are no compatibility issues - antenna is simple passive device.
Users browsing this forum: No registered users and 25 guests
