RobClem
60km running 5ghz-10mhz - bandwidth question
Fri Mar 16, 2007 11:59 pm
I have a pair of Wrap boards with CM9 cards running 5ghz-10Mhz over 60Km - I have a signal of -70 and can only get a maximum throughput of about 8Mb in each direction. The link is locked in at 36Mbps - any ideas why I am only getting 8Mb
thanks
Rob
MyThoughts
Sat Mar 17, 2007 7:08 am
Seems to me if your getting 8 Mbps across 60km with 5Ghz-10Mhz with a signal of -70 both directions while locked at an air rate of 36 Mbps, then its running as it should.
titius
Sun Mar 18, 2007 2:05 am
8Mbps full duplex?
then it is ok, and wrap maybe cant handle more.
marksx
Sun Mar 18, 2007 2:44 am
10MHz @ 54Mbits gives performance about 12-13Mbps half duplex (15Mbps with nsteme)
with 36Mbps mode performance is about 2 times worse = 7-8Mbps
You shouldn't be able to archieve more than that on these settings
Mikrotik Certifird Teacher - High Performance Wireless Networks Administrator
Contact: marek (at) prowireless.pl
RobClem
Sun Mar 18, 2007 9:32 pm
thanks for that - kinda what I was thinking. I established the link using 10Mhz chanels to assist the link, I shall try it with normal 20mhz channel to see if I can improve the throughput now.
Rob
marksx
Sun Mar 18, 2007 11:08 pm
yeah, but probably, you'll need to switch negotioation rate to 24Mbps (becasue signal on 20MHz is -3dB comparing to 10MHz)
That should give you about 17Mbps simplex
And of course setup nstreme /w polling enabled
framer-policy=exact-size & framer-limit=4000
that'll speedup connection to it's limit.
phendry
Thu Mar 22, 2007 1:31 pm
With slower CPU boards like the WRAP isn't it better to run Nstreme with framer-policy=best-fit?
marksx
Thu Mar 22, 2007 2:34 pm
no, best fit on high load can cause packetloss
exact-size gives you the best performance
phendry
Thu Mar 22, 2007 3:17 pm
Hmm. Is this the same for PTM or just PTP?
marksx
Thu Mar 22, 2007 4:46 pm
both, sometimes you can experiment with these settings, but i often set back old values
onowojemma
Re: 60km running 5ghz-10mhz - bandwidth question
Mon Mar 26, 2007 12:39 am
thanks
pls i want to run a link like this what type of anterna did you use for the link and how many dbi?
Rob
Mikrotik! making networking easy
Users browsing this forum: dhelazt and 39 guests
