jbird
Superchannel on ac radios?
Wed Feb 20, 2019 11:27 pm
I've been unable to enable Superchannel on any MikroTik ac radios that we've purchased. My organization is permitted to use 4.9 GHz, and I am trying to set a NetMetal 921UAGS-5SHPacD to 4.9 GHz. I've upgraded the license key to support extra channels, and it shows the "Extra-channels" feature on System | License. However, in the wireless settings, Frequency Mode is stuck on regulatory-domain, Country: United States3. Is it a characteristic of all MikroTik ac radios that they cannot operate in Superchannel mode?
R1CH
Forum Veteran
Forum Veteran
Re: Superchannel on ac radios?
Wed Feb 20, 2019 11:44 pm
You need the international version if you want unlocked frequencies.
- RB921UAGS-5SHPacT-NM-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
- RB921UAGS-5SHPacT-NM (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations).
Do note that 4.9 GHz is still outside of the supported frequency range so results may vary.
Paternot
Long time Member
Long time Member
Thu Feb 21, 2019 1:36 am
You got an USA version - check the product page:
https://mikrotik.com/product/RB921UAGS-5SHPacD-NM
"RB921UAGS-5SHPacT-NM-US (USA) is factory locked for 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed."
"RB921UAGS-5SHPacT-NM (International) supports 5150MHz-5875MHz range (Specific frequency range can be limited by country regulations). "
robertkjonesjr
Sat Mar 02, 2019 10:11 pm
As in this device, as well as others:
>> RB962UiGS-5HacT2HnT-US (USA) is factory locked for 2412-2462MHz, 5170-5250MHz and 5725-5835MHz frequencies. This lock can not be removed.
I see the US versions do not include UNII-2, or DFS channels. They are allowed in the US, so what is the reason of the lockout?
ranpha
Sun Mar 03, 2019 4:43 pm
Highly likely it is because they are not certified to use DFS channels.
Users browsing this forum: No registered users and 42 guests
