isyrider
Huge Problem - Urgent - WiFi Performance Problem
Mon Feb 25, 2019 11:45 am
The test:
iperf server on a notebook connecte via ethernet cable to a lancom switrch
iperf client on a one plus one 6 smartphone
first test with a cheap portable tplink ap tl-mr3020 on 2.4GHz
result medium bandwidth 46.1M NO retry
second test a mikrotik rbwapg-5hact2hnd-be on 2.4Ghz fw 6.40.b8
result medium bandwidth 31.7M a lot of retry
second test a mikrotik rbwapg-5hact2hnd-be on 2.4Ghz fw 6.43.12
result medium bandwidth 27.6M a lot of retry
same ethernet port, same wifi channel, same ap position, same everything.
The mikrotik rbwapg is with no configuration just bridge eth1-wlan1
Attach the iperf test
vecernik87
Long time Member
Long time Member
Re: Huge Problem - Urgent - WiFi Performance Problem
Mon Feb 25, 2019 12:45 pm
Do you really believe that placing word "urgent" in title will make it solved faster? Well, good luck.
chechito
Mon Feb 25, 2019 2:49 pm
x2
anav
Mon Feb 25, 2019 2:57 pm
Giving birth must be a National Emergency. ;-)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
isyrider
Mon Feb 25, 2019 3:29 pm
Very funny,
I have a brand new installation and nothing is working as it has to.
Find that a cheap tplink has better performance that a mikrotik was a little bit shock.
I don't know if mikrotik is the best choice for an installation like this.
So I hope that is something I'm doing wrong and a Mikrotik wifi ap is better than a 15$ tplink portable ap.
anav
Mon Feb 25, 2019 4:08 pm
More than likely human error but do post your config.......
/export hide-sensitive file=yourconfigfeb25
Users browsing this forum: Google [Bot] and 10 guests
