alnet
MantBox with sxtq and lhg ac - Bad CCQ
Sun Mar 10, 2019 12:01 am
Hi all!
I read several posts on the subject but none with solution apparently.
in several cities and different noise scenarios I see that the MantBox has some problem (we use 15 and 19) With optimal signals (between -50 to -70) we get really low CCQ (5 to 30%) so the throughput is collapses
We use Ap only AC, Nv2, for the moment at 20mhz because the performance is low. Are there ways to improve this?
The channel is at 0% of use and the snooper does not find stations either, so the 5300 channel is good. In 5800 it gets worse.
Any recommendation?
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac country=argentina \
    default-forwarding=no disabled=no disconnect-timeout=5s frequency=5300 \
    frequency-mode=superchannel hide-ssid=yes mode=ap-bridge nv2-cell-radius=10 \
    nv2-preshared-key=wpm18 radio-name=AP_PM_NORTE security-profile=SEGURIDAD \
    ssid=AP_PM_NORTE tdma-period-size=auto wds-default-bridge=bridge1 wds-mode=\
    dynamic wireless-protocol=nv2
Design, implementation and troubleshooting of wired and wireless networks (FTTx, Wireless, ADSL). Traffic control and bandwidth. VPN, PPPoE and tunnels. Advanced firewall security. Dynamic routing (OSFP, BGP). Assistance support to companies and ISP.
spacex
Re: MantBox with sxtq and lhg ac - Bad CCQ
Sun Mar 10, 2019 12:15 am
nv2 will return to normal when this is normal traffic
adilsemedo
Mon Mar 11, 2019 3:11 pm
Try to use N/AC band, and CW to 20/40 Mhz... if the radio detect free free air will use 40 Mhz or 20 if it´s noised.
band=5ghz-n/ac channel-width=20/40mhz-Ce \
And mANT must be shielded to better performance, the matterial is plastic type.
WISP Engineer
MTCNA MTCRE MTCWE
InoX
Mon Mar 11, 2019 5:42 pm
Isn't this your problem?
viewtopic.php?f=7&t=136002
honzam
Mon Mar 11, 2019 7:24 pm
It is solved in 6.44
LAN, FTTx, Wireless. ISP operator
spacex
Mon Mar 11, 2019 9:05 pm
Test client to ap bandwith test check it.
InoX
Tue Mar 12, 2019 1:03 am
I know, does he?
Users browsing this forum: No registered users and 12 guests
