KaSp3rSky
hAP ac wireless problem
Mon Apr 08, 2019 5:43 pm
I bought hAP ac router and don't changed default settings. I have problem with wireless. Every time when I measured speed, on laptop result is about 80Mbps, but on mobile devices show about 50Mbps. Why on mobile devices speed flow is not max?
R1CH
Forum Veteran
Forum Veteran
Re: hAP ac wireless problem
Mon Apr 08, 2019 6:58 pm
Default settings are probably not good for your environment. Pick correct frequency, channel width, enable WMM, set country, etc.
nostromog
Mon Apr 08, 2019 7:45 pm
I checked here, with different routers, but I find, in registration table, that the laptop is typically connected as 150Mbps-40 MHz/1S/SGI (...) 243Mbps-40Mhz/2S/SGI ... while the phone usually shows 65Mbps-20MHz/1S/SGI 72Mbps-20MHz/1S/SGI. The hAP ac^2 I'm testing with here has 2 chains, so 2 is maximum. Yours has 3 chains...
It might be due to the cellular wanting to save energy or that the chip that the phone has is less performant, but check the specifications. Someone said recently here that, as a rule of thumb, you get ~ half of the nominal wireless. So here my laptop is getting (not testing, quite idle) ~75Mbps while the phone would get ~35, consistent with your observations.
KaSp3rSky
Mon Apr 08, 2019 10:55 pm
Before hAP ac, I used yet three other mikrotik routers. I didn't have any problem with wifi on default settings. How can I fix this?
I tested my phone and two other phones on other network, speed wich shows on speed test are about 200Mbps.
neutronlaser
Tue Apr 09, 2019 5:21 pm
boring 'wifi not fast enough must have top speed for no particular reason but can't be bothered to read or post config' post
anav
Tue Apr 09, 2019 8:44 pm
Please post config...
/export hide-sensitive file=yourconfig
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
eddieb
Tue Apr 09, 2019 8:51 pm
wireless speed issues were discussed here several times. Perhaps you should search this forum ...
like : viewtopic.php?f=7&t=132384
Running 6.47.2 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, RB750Gr3 running dude
neutronlaser
Tue Apr 09, 2019 9:21 pm
PS Set channel width to 80MHz, and separate SSID for 5GHz to force your device to use it, if your main goal is speed.
KaSp3rSky
Wed Apr 10, 2019 10:36 pm
This is my setup. If I understand good, no have solution for this problem?
# apr/10/2019 21:30:05 by RouterOS 6.44.2
# software id = ZBS9-0IN1
# model = RouterBOARD 962UiGS-5HacT2HnT
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=serbia disabled=no distance=indoors frequency=auto mode=ap-bridge \
    ssid=Fenixx wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=serbia disabled=no distance=indoors frequency=\
    auto mode=ap-bridge ssid="Fenixx 5Ghz" wireless-protocol=802.11 \
    wmm-support=enabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp-18 ranges=192.168.18.10-192.168.18.40
add add-arp=yes address-pool=dhcp-18 disabled=no interface=bridge name=\
    defconf
/queue type
add kind=pcq name="Download 100M" pcq-classifier=dst-address,dst-port \
    pcq-dst-address6-mask=64 pcq-rate=100M pcq-src-address6-mask=64
add kind=pcq name="Upload 6M" pcq-classifier=src-address,src-port \
    pcq-dst-address6-mask=64 pcq-rate=6M pcq-src-address6-mask=64
/queue simple
add name=kasp3rsky queue="Upload 6M/Download 100M" target=192.168.18.10/32
add name="coa mob" queue="Upload 6M/Download 100M" target=192.168.18.11/32
add name="nVidia Shield" queue="Upload 6M/Download 100M" target=\
    192.168.18.12/32
add name="Phillips Hue" queue="Upload 6M/default-small" target=\
    192.168.18.13/32
add name=Bojana queue="Upload 6M/Download 100M" target=192.168.18.14/32
add name="Bojana Mob" queue="Upload 6M/Download 100M" target=192.168.18.15/32
add name="Bojana Mob sluzbeni" queue="Upload 6M/Download 100M" target=\
    192.168.18.16/32
add name="Sony TV" queue="Upload 6M/Download 100M" target=192.168.18.18/32
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.18.1/24 comment=defconf interface=bridge network=\
    192.168.18.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
/ip dhcp-server lease
add address=192.168.18.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
    gateway=192.168.18.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system clock
set time-zone-name=Europe/Belgrade
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: No registered users and 49 guests
