SharkovIA
Two independent wifi channels on one device
Thu Apr 18, 2019 12:12 pm
Is there any solution how to make two AP on BaseBox2 (RB912UAG-2HPnD-OUT), that use different wifi channels?
Can I do it without additional modules?
If it impossible, help me to select BaseBox2 (RB912UAG-2HPnD-OUT) compatible miniPCI module for creation second independent 2.4GHz. wifi channel, please.
normis
Re: Two independent wifi channels on one device  [SOLVED]
Thu Apr 18, 2019 2:03 pm
No, any kind of virtual access point entries will use the same frequency as the master interface.
honzam
Thu Apr 18, 2019 2:08 pm
https://mikrotik.com/product/R11e-2HPnD
LAN, FTTx, Wireless. ISP operator
Users browsing this forum: No registered users and 30 guests
