cavel
wAP 60Gx3 problem
Wed Apr 24, 2019 12:18 pm
Hello, I had a wAP 60G connection with two clients. One wAP 60G (150m) and one LHG 60G (400m) at about 50 degrees. I wanted to connect one more client out of 60 degrees. I exchanged wAP 60G for wAP 60Gx3, still with two clients. Clients have often started to disconnect since the replacement, 150 disconnections in 8 days. So I returned everything to wAP 60G. Is there any advice why wAP 60Gx3 didn't work?
thanks, Pavel
mistry7
Re: wAP 60Gx3 problem
Thu Apr 25, 2019 3:22 am
That is Bad news, we want to Test this Sector in the Next Week in real Setup
marcin21
Thu Apr 25, 2019 6:33 am
did You try the exact same ROS version on both WAPs?
asterisco
Tue Apr 30, 2019 8:03 pm
I noticed at least 3 dB less in signal reception in the WAP60x3 compared to WAP60
cavel
Fri May 03, 2019 5:22 pm
Yes, it's same version od ROS
cavel
Mon May 13, 2019 11:44 am
any news??
server8
Mon May 13, 2019 1:43 pm
ROS version?
normis
Mon May 13, 2019 3:34 pm
make sure you run the latest RouterOS version on both sides, and then send us both supout.rif files.
Email them to support @ mikrotik and we will see why it's different on the 60Gx3
marekstejskal
Tue Aug 04, 2020 9:27 am
Any news?
enlace101
Fri Jan 01, 2021 1:31 pm
We need to implement this solution in all our nodes to release load on the NV2 APs.
Any news about this problem?
thanks
Sorry Google translate
Users browsing this forum: No registered users and 52 guests
