HWATech
Hotspot Configuration
Fri Apr 26, 2019 12:52 am
Hello, New to this forum and fairly new to mikrotik.
I was wondering if anyone knew about or experienced the issue of connecting a mobile device to the mikrotik hotspot, and not able to go any further than the login screen. It seems to keep me in the "status" page, and when i back out to go to a webpage, it prompts me saying i am not connected to the internet. I can however, bypass the prompt and tell it to keep me on the mikrotik anyway, and i will be able to browse the web on that same network, therefore being connected to the internet. I am planning on utilizing this for some hotels, and would like to get it to just have an agreement page, rather than a user login page. I have the script for that, however with that it still does a similar thing, and it keeps me locked in what seems to be a browser in the wifi settings. I also added a script with a link on the status page, but all that is able to do is open a link in a new tab of the same browser, which is still in the wifi settings itself.
The issue of course, is not happening with desktops.
Exiver
Re: Hotspot Configuration
Fri Apr 26, 2019 10:14 am
Please post your configuration:
/export hide-sensitive
pcunite
Forum Veteran
Forum Veteran
Fri Apr 26, 2019 2:55 pm
There is an issue with iPhones and using the HotSpot 'address-pool' option. It is a NAT helper. Set it to none and see if your issue is resolved.
HWATech
Fri Apr 26, 2019 5:23 pm
I attempted to change the address pool to none, and that didn't seem to change anything.
here is the configuration
# apr/26/2019 08:49:16 by RouterOS 6.44
# software id = 4BC0-S4BA
# model = RouterBOARD 750 r2
# serial number = 67D408F0C568
add admin-mac=******************* auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add dns-name=www.mikrotest.com hotspot-address=10.0.0.1 html-directory=\
flash/hotspot login-by=cookie,http-chap,https,http-pap,mac-cookie name=\
hsprof4
/ip hotspot
add disabled=no interface=bridge name=hotspot1 profile=hsprof4
/ip hotspot user profile
set [ find default=yes ] shared-users=200 transparent-proxy=yes
add name=dhcp ranges=10.0.0.10-10.0.0.254
add name=hs-pool-1 ranges=\
192.168.88.1-192.168.88.100,192.168.88.102-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=hs-pool-1 disabled=no interface=ether1 lease-time=1h name=\
dhcp1
add address=10.0.0.1/24 comment=defconf interface=ether2 network=10.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1 netmask=24
add address=192.168.88.0/24 comment="hotspot network" gateway=192.168.88.101
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.0.0.1 name=router.lan
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.0.0.0/24
src-address=192.168.88.0/24
/ip hotspot user
add name=******* password=*********
/ip proxy access
add action=deny redirect-to=10.0.0.1
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
Exiver
Fri Apr 26, 2019 10:30 pm
Your config looks a little bit "unfinished" if im allowed to say that. You have one dhcp-server running on ether1 while having a dhcp client on the same interface? It looks like your uplink interface is indeed ether1 so this should be not needed.
I guess the problem is occuring because of the two following things:
* Your DHCP-Server is not configured to announce a DNS-Server (/ip dhcp-server network). You should set that option to your routers address as well (10.0.0.1)
* IP address set on the device. The ip 10.0.0.1/24 is set on ether2 while ether2-ether5 are members of the Bridge bridge. Addresses should be always assigned to the bridge-interface.
Users browsing this forum: Google [Bot] and 12 guests
