lemonmagic
Capsman with 2 Provisioning configs
Fri Apr 26, 2019 7:47 pm
I installed several Cap ac's at a clients place with 2 Buildings.
Both Buildings are having there own Guest SSID, and the same Staff Vlan SSID,
so I will need 2 different provisioning Setups on the same Capsman.
Building 1: Vlan 10 - SSID: Staff
Vlan 20 - SSID: Guest-B1
~ 8 Cap ac's
Building 2: Vlan 10 - SSID: Staff
Vlan 21 - SSID: Guest-B2
~ 5 Cap ac's
Question: How do I select which cap will be using Provisiong config #1, and the others using #2 ?
Exiver
Re: Capsman with 2 Provisioning configs
Fri Apr 26, 2019 10:14 pm
There are some howtos accessible via Google and there is the wiki article which explains how to setup a master/slave configuration:
https://wiki.mikrotik.com/wiki/Manual:CAPsMAN#Examples
There are different setups possible: Which router are you using as a capsman? I would suggest to setup the configuration in capsman-forwarding mode since you can easily build datapaths with bridges and vlans on the capsman router thus having only "dumb" access points getting their configuration from the capsman and forwarding all traffic via a tunnel.
Things you should think about when setting this up:
You would first create one master configuration for 2,4 and one for the 5ghz interfaces. (Best would be to have your internal network as master since its consistent between all access points).
Then you would add two slave configurations - one for building #1 and the other for building #2 as guest networks.
Provisioning rule can now be matched either by the clients identity (on Client /sys identity) AND hw-supported-modes (to distinguish between 2,4 and 5ghz master config) or you can match the radios by their mac-addresses (thats what we do, but that produces more provisioning rules - 2 * amount of caps).
https://wiki.mikrotik.com/wiki/Manual:C ... ovisioning
Users browsing this forum: MSN [Bot] and 22 guests
