donsergio
Optimize SXT Lite 5 PtP Link , bad CCQ
Mon May 06, 2019 10:46 am
Hi, I´m trying to get best CCQ on a PtP with a pair of SXT Lite 5, but CCQ is not stable... is about 50-80 % on both rx/tx... I tried the solution of this post:
viewtopic.php?t=71564&sid=b1c1c348d2035 ... ecf04b8a61
But when I do the changes CCQ rise up to 100% both rx/tx, one hour later it drop to 40%.... tried to change frequencies with no luck....
This is my export from ptp AP.... STA has the same config (but in STA config)... the links has full line of sight
# may/06/2019 09:37:21 by RouterOS 6.43.2
# software id = xxxxxxx
# model = SXT 5nD r2
# serial number = xxxxxxxxx
add fast-forward=no name=bridge1
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6 antenna-gain=10 \
    band=5ghz-a/n basic-rates-a/g="" country=spain default-forwarding=no \
    disabled=no frequency=5280 frequency-mode=regulatory-domain ht-basic-mcs="mc\
    s-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-\
    12" ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,\
    mcs-9,mcs-10,mcs-11,mcs-12" mode=bridge nv2-preshared-key=\
    nv2-password nv2-security=enabled radio-name=ptp-air rate-set=\
    configured ssid=ptp-air supported-rates-a/g="" wireless-protocol=nv2
add bridge=bridge1 interface=wlan1
add address=172.16.126.30/23 interface=bridge1 network=172.16.126.0
add distance=1 dst-address=172.16.127.254/32 gateway=bridge1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
/system identity
set name=ptp-air
jarda
Re: Optimize SXT Lite 5 PtP Link , bad CCQ
Tue May 21, 2019 9:30 am
Distance, fresnel zone, alignment, interference. You wrote nothing about them, but you are missing 10db of signal level. You cannot beat the physics by any parameters. You can lower the tx power if devices are too close, you can lower the modulation, you can use more narrow band or change the frequency but that's almost all. What speed you need to achieve?
donsergio
Sun May 26, 2019 8:22 pm
Hi, it´s for about 500 meters and with 100 mbps aggregate it´s sufficient...
Finally.... lot of tests.... lot of configs, solved with a pair of nanobeam ac gen2
Thanks !!
todayheads
Mon Jun 03, 2019 2:24 am
put them on sat dishes as reflectors and signal would enhance to about -30s
mistry7
Mon Jun 03, 2019 6:44 am
Thanks !!
For 500m you Better Choose a 60Ghz Product
Users browsing this forum: No registered users and 7 guests
