qbic
R11e-LTE firmware bug.
Tue May 21, 2019 10:31 am
After installing "MikroTik _CP_2.160.000_v011" passthrough mode is not working anymore.
If you are using this mode, I strongly advise against installing latest FW.
How to downgrade R11e-LTE firmware ?
sebastia
Re: R11e-LTE firmware bug.
Wed May 22, 2019 12:07 pm
Hi
Do you have IP reverse path filter set to strict on lte modem? Try lowering it, loose should be enough.
qbic
Wed May 22, 2019 7:53 pm
(I've set it to loose on both devices, IP/Settings RP Filter, anyway it was set to no). No change.
Configuration is as it was, the only thing that i've changed is LTE modem firmware :/
Still no go.... I would like to downgrade firmware if possible :-/
Wap-LTE (eth1) <-> (eth1/wan) Hex3
Now, I've upgraded firmwre of the wap-lte to testing, and seems that default gateway received on the router side is "better" (not some strange subnet) but it still does not work.
qbic
Fri May 24, 2019 3:27 pm
Any other ideas how to fix this ?
qbic
Tue May 28, 2019 11:52 am
OK... so maybe someone know where I can find old firmware files?
Seems that I can specify file to upgrade/downgrade(?) FW in R11e-LTE modem...
miencek
Mon Jun 03, 2019 3:23 pm
Hello.
I also confirm this error. I had to turn off the passthru mode to make anything work.
miencek
Tue Jun 04, 2019 3:12 pm
My battles with the LTE R11e-LTE modem
Hello.
I would like to extend my previous post and describe how the LTE devices in remote locations were implemented.
1) View of installed equipment
In remote locations, the following network layout has been damaged in part due to historical reasons, and also to be able to take advantage of LTE multiAPN functionality.
The general diagram of network connections
(LTE Service Provider) <-> (LTE Modem in MultiAPN Mode) <-> (Remote Router) <-> (Devices)
In remote locations, the built-in system is as follows:
1) Installation of LTE modems
A view of built-in routers at remote locations that provide connectivity with devices installed in a given location.
2) Description of communication
The router with the LTE modem communicates using vlanes. For the two APN LTE configured in the modem, two vlans have been assigned to which the lte passthrough mode has been configured. On the router, the dhcp client runs on these two vlanes, which reads the addresses and configures the necessary routes using the script.
3) Problem with the modem.
On some devices it happens that communication is interrupted. This is manifested in the fact that the connection made by the LTE modem indicates that packets are sent but there are no returnable packets.
Below I presented such a situation (server is pinged with a package size of 1024)
And on the router the situation looks like this:
Disabling the LTE interface
Enabling the LTE interface - the interface disappears from the list
- interface appearance
- restoring communication on the router after restarting the modem
- modem version
This problem occurs for the software version 2.160.000_V008 and 2.160.000_v010.
For software version 2.160.000_v011, the LTE passthrough mode is bordering on a miracle.
As for me, this problem lies in the modem firmware. No return packets from the interface, disappearing interface during the restart indicate a problem in the modem. I suspect that some part of the software hangs.
Dear Mikrotik! Please, repair the LTE modem. I plan to implement new sets and breaking up communication is very troublesome.
robpeng
Thu Jun 06, 2019 6:36 pm
Hi Miencek,
Really tidy setup! Question, how do you connect an external antenna to the WAP LTE unit?
qbic
Fri Jun 07, 2019 11:17 am
You should look here:
https://i.mt.lv/cdn/rb_files/guide_wapr ... 104404.pdf
I also have external antenna, without it device is quite useless, even basic huawei LTE stick is reaching far higher speeds without external antena in same location, but other features makes up for it (like external IP forwarding to other NAT device... which now is not working).
I have idea this CRAZY idea, why we do not have any changelog for R11e-LTE firmware and old files for the modem like for the rest of the Mikrotik stuff?
robpeng
Fri Jun 07, 2019 2:15 pm
Have you tried out any of the HEX equipment? https://mikrotik.com/product/RB750Gr3
I have seen people use one of these with a USB LTE dongle plugged into it, would that would for your use case?
I have a few STX LTEs myself but would be interested to see how some of the gear works with other LTE chips/dongles
qbic
Fri Jun 07, 2019 4:57 pm
No its tricky, some dongles have built-in NAT with crappy performance. Actually my setup is WAP-LTE kit with Hex3 as a client, where normally Hex receives ip from the operator in pass-through mode.
R11e is not a bad product when it works, but it is a little bit tricky to squeeze out performance out of it.
robpeng
Fri Jun 07, 2019 5:18 pm
Interesting, I haven't played around with the passthrough stuff.
I think the LTE interface is bridged to eth1 on my STX LTE, is there an advantage to enabling pass-through mode? Would a need a firewall then on the client/device on eth1 then?
qbic
Wed Jun 12, 2019 3:35 pm
So mikrotik do not care about R11e FW bug?
qbic
Sun Jun 30, 2019 11:08 am
Problem is fixed in latest firmware "MikroTik_CP_2.160.000_v012"
roe1974
Wed Jul 03, 2019 12:31 pm
@miencek
Where do you get the "holder" for the mikrotik Antenna ?
regards, richard
aex
Thu Aug 01, 2019 7:49 pm
Hello, everybody,
I have a question about r11e-lte.
After I updated the firmware to version MikroTik_CP_2.160.000_v012, the LTE connection breaks regularly at least twice a day. is it possible to downgrade the firmware?
greetings
krafg
Long time Member
Long time Member
Mon Aug 05, 2019 4:19 am
Downgrades are not possible yet.
Regards.
If you want to know my network, you can find it here.
qbic
Wed Aug 07, 2019 11:43 am
This is interesting, because you can flash from file... I have somewhere 008v.
greek
Fri Oct 25, 2019 2:53 pm
I have big problems with wAP-LTE and R11e-LTE cards.
I use MultiAPN function with same APN (example present in wiki https://wiki.mikrotik.com/wiki/Manual:I ... gh_Example ):
1st APN profile APN=MyApn user=user1 pass=pass1 passthru=no
2nd APN profile APN=MyApn user=user2 pass=pass2 passthru=yes int=ether1
This config work fine until reboot. After reboot sometimes LTE is UP, sometimes not work and lte card do nothing with "functionality = minimum"
After 5-6 reboots first R11e-card died (not seen in system - resources - usb), second R11e-LTE card "finding network" and go to "Unknown Status" infintly.
2 cards died ¯\_(ツ)_/¯ "MikroTik_CP_2.160.000_v013"
sergio8
Wed Mar 11, 2020 6:55 pm
Have same issue on WAP LTE kit with EU R11e-LTE "MikroTik_CP_2.160.000_v013"
Cycle on Searching --> Registering --> Denied....
SiB
Forum Veteran
Forum Veteran
Mon Mar 16, 2020 2:56 am
Sorry, this model can be upgrade only by itself lte1 with internet on it. Please change the SIM or ISP to get internet connection.
You can do the upgrade ROS before to stable=6.46.4 and repeat but in my opinion only change sim/isp can give you a internet.
Remember to not use dhcp server name - the same name in APN/ThroughtMode.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
SiB
Forum Veteran
Forum Veteran
Mon Mar 16, 2020 10:16 am
Disable ROAMING and be sure that operator is blank and APN have a proper name.
Users browsing this forum: No registered users and 29 guests
