gotsprings
2.4 4-way handshake timeout
Sat May 25, 2019 5:47 pm
This seems to have come back on me.
Router OS is 6.44.3 on hEX and cAP AC
devices on the 2.4 radio are disconnecting from the wifi. Log into the router and check the logs and see...
(MAC of Devices) disconnect 4-way handshake timeout
Devices on 5Gig radio do not show this error.
Last time I reported this, support would send me one email per month... I removed the Tik Wireless and Went to Ruckus and stopped getting angry calls.
MIKROTIK SUPPORT...
I just submitted a support file via email. Please take a look at it and figure out what is wrong.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
gotsprings
Re: 2.4 4-way handshake timeout
Sun May 26, 2019 10:58 am
Took cAP out of caps-mode.
Same result. Well sort of. Log file showed unicast key time out.
Went back to caps mode and added an unencrypted SSID. Devices connected for about 10 seconds. Then I got a disconnected for extensive data loss.
Looked up several old posts tagged with extensive data loss. They all pointed to "interference".
Changed the 2.4 channel between 1 6 and 11 and all had the same result.
Changed 2.4 channel to auto... cAP chose channel 3. Devices connected. One device still showed 4 way hand shake time out after reading the encryption... But 5 devices do connect to 2.4. During the whole problem... I could not get a client to connect to 2.4 at all.
Mikrotik wireless is coming out Tuesday. Will be trying the Ruckus R510 in the same spot.
Mark Twain
gotsprings
Sun Jun 02, 2019 11:36 pm
Still nothing from support.
Mark Twain
BRMateus2
Mon Jun 03, 2019 3:50 am
Did the Ruckus work? I've never seem something like this, are you sure there is no jammer nearby? Jammers don't show in any of the WiFi protocol scans.
gotsprings
Tue Jun 04, 2019 8:23 pm
I struggle to recall an install in the last 10 years that it hasn't.
Mark Twain
gotsprings
Wed Jun 05, 2019 3:11 pm
For anyone keeping score... Still no email from Mikrotik support.
Mark Twain
gotsprings
Mon Jun 10, 2019 1:02 pm
Got email from Mikrotik. Explained the problem and how to reproduce it.
They did... And don't currently have a fix.
So high density with interference... If you see 4-way handshake time out in Caps-man...
Don't fight it. Don't mess with support. Just buy the Ruckus radio and move on.
Mark Twain
ivicask
Tue Jun 11, 2019 2:47 pm
I get those also with capsman, after changing some stuff and channels it got reduced, but still get them daily.
zaza355N
Thu Jun 13, 2019 1:03 am
I had exactly the same story on a big event with 12 sxt sq lite 2, it was awe full, i tried basically everything, for 5 hours, then i just moved to another brand then it worked...
I was also using CAPsMAN.
I am interested to know why that can happen
Thank you
gotsprings
Thu Jun 13, 2019 5:53 am
Thank you
Because some vendors can deal with interference better than others.
I watched a YouTube video linked by Mikrotik. A "respected expert" talked all about frequencies and airtime and "when it's out of space, it's out of space."
I call B--lshit!
I have seen "UniF--k" crumble under the same sort of stress.
But an 8 year old Ruckus systems "cuts right through it."
Mark Twain
gotsprings
Mon Jul 01, 2019 1:44 pm
Amazon seems to have a steady flow of Ruckus at ~50% off retail.
Mark Twain
gotsprings
Fri Aug 23, 2019 1:40 pm
Tech in the field (related to owner, so I was out ranked) insisted on putting in the cap AC he had in his truck.
In the days since. Customer has been pounding him with complaints for the last week. Calling everyday. We get into the configuration and try to adjust things... But this is another site where it's just not going to work.
They have a Ruckus on one building and it has no problems at all. Where client devices transitions to the Tik wireless that "are in less important spots" (yeah... That was the excuse for adding in the Tiks where the Ruckus works) is proving a disaster.
70 bucks vs 270 bucks... I see why he tried it. But that 200 dollars cost us the customers confidence. Will probably have to take out everything, as they will likely not let us change out just the wireless.
Mark Twain
inteq
Sat Feb 06, 2021 6:44 pm
U R funny. Check https://forums.ruckuswireless.com/conve ... e247913632
gotsprings
Sun Feb 07, 2021 3:49 am
I was really hilarious when I got one email per month, for 4 months, as my clients would not connect from Mikrotik support.
I had a dozen installs with the same problem that Mikrotik flat out told me... "It's your environment."
Stopped using Mikrotik wireless and my problems went away instantly.
Mark Twain
Users browsing this forum: No registered users and 77 guests
