todayheads
LHG 60GHz Wireless Wire
Sun Jun 02, 2019 3:24 am
i by mistake swapped the station and bridge
i reconfigured station to be bridge and bridge to be station bridge but they are not connecting
how can i achieve that
2frogs
Long time Member
Long time Member
Re: LHG 60GHz Wireless Wire
Sun Jun 02, 2019 4:51 am
I made the same mistake and tried to reconfigure them as you did. I ended up having to reset to default and swapping the units. I wonder if the slave in the set is only capable of being CPE.
mistry7
Re: LHG 60GHz Wireless Wire  [SOLVED]
Sun Jun 02, 2019 11:01 am
You need to Remove the w60g-Station Interface, After a connect it is created new
todayheads
Mon Jun 03, 2019 1:17 am
thanks, i did that and also from station side SSID same as Bridge SSID and worked like charm
but i wounder if same name might loop the network :o
Users browsing this forum: Tobei and 27 guests
