chesk
Connection refused - login redirect hotspot fail when activate hotspot server
Sun Jun 02, 2019 9:43 pm
In another topic present the problem of not being able to redirect to a local radius server, thinking that it was by rules like of hairpin nat.
Reading similar problems like this one.
viewtopic.php?t=22713
I see that the problem originates with the web proxy of the hotspot.
I can access from the outside, from the lan and through the activated dhcp server to the local server through the public ip.
But when I activate the hotspot server, I do not have access to the site, neither by IP nor by domain. Even if they are added in the walled garden, the trasnparent proxy disabled, does not work.
The web proxy is also disabled, but what you see in the attachment is working the same?
The firmware version is 6.44.3.
login.html must redirect to the domain https://hotspot.xxx.com with public IP, it is a local server with spotipo installed, for login with social sites.
Anyone knows how to solve this?
Users browsing this forum: No registered users and 33 guests
