mfr476
Netmetal ac triple + 3 omnidireccional antena. Is posible?
Sun Jun 09, 2019 6:28 pm
Hi! It is posible conect 3 omnidireccional antenas interline in vertical in netmetal triple or cpe can't Connect?
mdd
Re: Netmetal ac triple + 3 omnidireccional antena. Is posible?
Fri Jun 14, 2019 11:29 am
Hi i was thinkign about similar setuo but with different configuration anntenas:
1 x Ubiquiti Air Max 13dBi 5GHz DualOmni Antenna (AMO-5G13) connect to two RSPMA
1 x Normal Antenna Omnit connect to last ont RSPMA but pointig down.
Interesting what whould be ?
Mikrotik user from 2017
mfr476
Sat Jun 15, 2019 3:24 pm
It is interesting... Good and New ideas!
krafg
Sat Jun 15, 2019 8:24 pm
I prefer to use 3 good quality SISO antennas. For long distances the "third" antenna, hardly will do something.
Anyway on both devices needs to be compatible with MIMO 3x3 and using the same polarity in each antenna to get the best result and use the equipment at 100%.
Normally all the polarities in these cases are linear, but it can be horizontal, vertical or cross polarized (+45° -45°).
Regards.
mfr476
Sun Jun 16, 2019 3:14 pm
good idea¡ i want to use an omnidireccional interline vertical
Users browsing this forum: No registered users and 11 guests
