maddogslo
LHG LTE kit
Tue Jun 18, 2019 11:52 pm
I have LHG LTE device with SIM Croatian HT Mobile.
Mikrotik can connect to network on band 3 or 20. Problem is I can't ping any wan ip mikrotik (I have done nat, no firewall, route,apn..) for example 1.1.1.1 or 8.8.8.8. But very strange is that mikrotik self can donwload and upgrade firmware and get cloud address.
I am using latest firmware and I have also upgrade LTE modem to latest.
I am getting fustrated !
uldis
Re: LHG LTE kit
Wed Jun 19, 2019 9:06 am
Try to use this mangle rule:
https://wiki.mikrotik.com/wiki/Manual:I ... throttling
maddogslo
Re: LHG LTE kit
Wed Jun 19, 2019 12:57 pm
Hi, already done without success, I have changed R11e-4G with my old one R11e-LTE
I also tryed with all regular and testing firmware.
I heve questions
- can R11e-4G and R11e-LTE firmware be downgraded ?
- if yes how ?
- can be problem with firmware on R11e-4G ?
- can I change band in cli ?
my config
# jun/19/2019 05:46:02 by RouterOS 6.45beta62
# software id = LVUP-46NQ
# model = RBLHGR
# serial number = A333092606C6
/interface lte
set [ find ] mac-address=00:11:22:33:44:56 name=lte1 network-mode=lte
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] apn=internet.ht.hr authentication=pap name=internet
add apn=fms.ht.hr default-route-distance=1 name=apn1
/ip hotspot profile
add name=dhcp ranges=192.168.88.100-192.168.88.130
add address-pool=dhcp disabled=no interface=ether1 name=server1
set discover-interface-list=WAN
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
add interface=lte1 list=WAN
add interface=ether1 list=LAN
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip cloud advanced
set use-local-address=yes
    192.168.88.1 netmask=24
set allow-remote-requests=yes
add action=accept chain=forward
/ip firewall mangle
add action=change-ttl chain=postrouting disabled=yes new-ttl=set:65 \
    out-interface=lte1 passthrough=yes
add action=accept chain=srcnat disabled=yes
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 out-interface=lte1
add distance=1 gateway=lte1
/ip smb
set allow-guests=no
/ip upnp
set show-dummy-rule=no
/ip upnp interfaces
add interface=ether1 type=internal
add interface=lte1 type=external
/port firmware
set directory=flash
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=LTE
/system logging
add topics=lte
add topics=lte
/system ntp client
set enabled=yes primary-ntp=193.2.1.117
/system watchdog
set watchdog-timer=no
/tool sms
set allowed-number="" port=lte1 receive-enabled=yes
[admin@LTE] >
sebastia
Re: LHG LTE kit
Wed Jun 19, 2019 10:56 pm
This one is strange, masq doens't take dst-address as param...recreate without dst-address.
(ti's just a filter =all => no-op
Do you get point-to-point ip onyour lte1? if not this route will not work, needs an ip then
disable "/interface detect-internet" for time being. Once you have connectivity back...
Try resetting to default config, as alternative solution.
Grickos
Re: LHG LTE kit
Mon Jun 24, 2019 8:56 pm
I also have a question
- can RBSXTR-LTE firmware be downgraded ?
- if yes how ?
Since I've upgrade the firmware to "MikroTik_CP_2.160.000_v011", passthrough does not work.
The old firmware who worked "_v009". Mikrotik routerboard RBSXTR kit EU.
Sorry for my bad english
sebastia
Re: LHG LTE kit
Tue Jun 25, 2019 12:01 am
I'm in the same boat as you: updated firmware and lost pass-through!
Support stated that downgrade is not possible
I've opened ticket with support, but so far no news [Ticket#2019061722005789].
ditonet
Forum Veteran
Forum Veteran
Re: LHG LTE kit
Tue Jun 25, 2019 2:16 am
My setup is: LHG LTE, RouterOS 6.44.3, RouterBOOT 6.44.3, modem firmware "MikroTik_CP_2.160.000_v011" and pass-through works properly.
Configuration of this LHG LTE is not changed for 8 months, only upgrades are applied.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
sebastia
Re: LHG LTE kit
Tue Jun 25, 2019 11:37 am
Good for you.
You have different and newer hardware though...
Grickos
Re: LHG LTE kit
Tue Jun 25, 2019 1:54 pm
Works on ether port (router) - ether port (LTE) physically connected.
So I have to install a physical router-LTE cable. Ground floor - roof.
I've connected via VLAN.
I have LTE on the roof and I connect it to the nearest switch, and tagging the VLAN. It does not work anymore.
Users browsing this forum: xrayd, xvo and 28 guests
